heat issue driving me nuts - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 10-26-2010, 05:35 PM
Topdown Topdown is offline
Vehicle: 2008 Dodge Ram 2500 Mega
Rep:44
Topdown is on a distinguished road
no problem, I will check tonight when I get home.
I do know that after a 5 mile drive through town, on an engine that was already warm from a previous drive, hitting a couple stop lights and a couple stop signs, that the TOP radiator hose was not uncomfortable to touch... which seems odd to me as this is the hose that should be the hottest coming out of the engine.
I have not taken the time to get a reading on the temp coming out of the vents, at low after the 5-mile trip, the temp out the vents is luke-warm, nowhere near 140*.
also, the heater hose on the left of the engine was warmer than the hose on the right side of the engine (while facing the front of the truck), slightly... (could have been mentally cooler versus actually - I will check that tonight too) though neither were uncomfortably warm, definitely neither were warmer than the radiator hose.
yeah, its raining like mad and is 54* outside today... so while I am not excited about heading out to check, I need heat in the truck.
Oh, one other small note, the longer I drive the truck, the warmer the heater gets - again, it seems like its just not getting hot and my darn water-temp gauge is either bad or the engine is just never getting hot enough to register on the gauge (which starts at 130)
1997 White1500 - sold
2008 Silver 2500 Mega Cab
Old 10-26-2010, 06:38 PM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
OK, I've checked the following on my truck which is basically a stock 5.9. With the heat on hi and full hot setting I get:
- Both heater core hoses are too hot to keep touching for more than a couple of seconds. The passenger side (goes to intake) is noticably hotter than driver side (goes to w/p).
- Upper Rad hose is hot but can keep my hands on it, lower is noticably cooler.
- Rad water temp taken at the rad neck with a cooking thermometer is ~170*
- The guage in the cab shows just under 1/2 and partially covering the "2" in 210.
It is starting to sound like a stuck t-stat from what you are describing. I would compare against what I found on my truck and if you find cooler temps (vent air, hoses, guage, water temp at rad neck) then I would suggest something cheap like replacing the t-stat and going from there. Who knows, the stat might not be in there (like the old Chevy's in So Fla). Let me know if I can make any more checks for you. I've been to your location and you NEED heat!
Troy
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 10-31-2010, 03:36 PM
Rep:44
I finally had a chance to work on the Ram yesterday. thinking that it was a thermostat issue, thats what I went after first. Sure enough, the T-stat was a failsafe and had been stuck open.
I replaced it with another failsafe (I prefer them to fail open versus fail closed) and like magic, the temp gauge started working (though it didnt get very high, just to the line over 130* - but most importantly, the heater got nice and hot while at full-speed.
Thanks for all the input/help everyone... I appreciate it!
Old 10-31-2010, 11:36 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
Great news! Glad to hear things are heating up for you!! Appreciate you letting everyone know what the final outcome was. Stay warm!
Troy
Old 11-01-2010, 12:32 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
where is the blend door on these?
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
