Old 09-07-2010, 03:48 PM
Ttsnelson Ttsnelson is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Ttsnelson is on a distinguished road
Default Need tire help
I have a 06 1 tonne with fender flares a 2" level and air bags in the rear that seamed to restore the rake by lifting it about 2 in the back. I am looking at some 33" tires but they have an overstock of 35" by 12.5 for the same price. First off will they rub? Second will I have any negative side affects such as more problems on other areas of the truck due to the bigger heavier tire?
Old 09-08-2010, 01:05 PM
Rep:1625
I know with the 1500s, you need a 1/4" spacer up front with the 35's, but I'm not sure about your truck. Sorry I'm no help, hopefully someone else with more knowledge can chime in.
Any pics of your truck?
Old 09-08-2010, 02:04 PM
I do have custom 18s on it so they might have enough of an offset
Old 09-08-2010, 07:33 PM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
to fit 35s you would probably need more lift and you may still slightly rub i would stick with the 33s for a no hassel operation
Old 09-08-2010, 07:38 PM
mikeyj08 mikeyj08 is offline
mikeyj08 is on a distinguished road
I have 285 55 20 Goodyear Duratracs and so far I love them.
