Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 09-07-2010, 05:10 PM
mkarns mkarns is offline
Vehicle: 1997 Dodge Ram Ext. Cab 4x4
Color: Green/Silver
mkarns is on a distinguished road
Default Click.....Click.....Click.....
Hello all,
My left front wheel is making a clicking sound especially if I make a left turn.
Any idea what I'm gonna need to replace and how urgent is it?
It just started.....
Thanks experts!
M. Karns
Old 09-07-2010, 05:16 PM
iRESQu iRESQu is offline
Rep:2217
Without the details of your truck, it is hard to decipher. Please fill out your User CP with the details of your truck and hang tight, someone will chime in that's able to offer some great advice.
Old 09-07-2010, 05:23 PM
Resident Technician
Rep:1909
If you have a 4WD I would suspect the axle joints but as Paris said, we need a lot more info on your truck to make an educated guess.
Old 09-07-2010, 05:37 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Ball joints.
Old 09-09-2010, 02:03 AM
projectdodge1500's Avatar
projectdodge1500 projectdodge1500 is offline
Vehicle: 2012 Dodge Ram 1500
Rep:43
projectdodge1500 is on a distinguished road
Default Yep
Originally Posted by chithead View Post
Ball joints.
Just had mine done about a month ago, that clicking was coming from my right side, and would stop only when turning the opposite direction.
2012 Ram 1500 5.7-1993 Dodge Dakota 4.3-2012 Jetta-Crazy Custom Scooters
Old 09-12-2010, 04:31 PM
Color: Green/Silver
I have a 1997 SLT 4x4 ext. cab. 5.2 L engine 5 speed.
Thanks.....
Old 09-21-2010, 04:14 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I'd say front axle joints, but if you've got a Jack and a jackstand you can test all your LH components in a couple of minutes.
Set transfer case in 4h (with motor on) When CAD is engaged shut off the motor. Set your emergency brake, jack up your lh side of the axle and secure it with a stand. Safety first!
First check your hub bearings. Grab the tire at 12:00 and 6:00 (top and bottom) and try to move it. Any play or wobble is a bad hub bearing. May not be THE problem but will be a problem. There's no need to rotate the tire. so 4wd engaged is ok.
Nsxt, check your ball joints. Using a pry bar or appropriate tool, slip it between the axle and the hub or in such a way you can pry up on the hub. If the hub moves (the factory allows .060") your joints are worn.
Lastly check your u-joints. Since your axle is locked, rotate the tire and watch for movement between cup and cross. BTW, rusty looking dust around the caps or grease is a bad sign. There may be play from gear back lash which is why you want to observe carefully. You can also use your prybar to move the joint. Any play at all means replacement.
PS: I realize I posted what may be obvous information for many folks. I also know many inexperienced people also read these threads who may not be sure how to check these components. I apologise to anyone who feels I overstated the obvious.
Old 09-21-2010, 04:19 PM
SafetyGuy SafetyGuy is offline
Vehicle: 2008 Dodge Ram
Trim Level: Big Horn Edition
SafetyGuy is on a distinguished road
^^ nope i feel very good information ^^ Rep you
Old 09-21-2010, 04:21 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
GRAVEL IN THE TREADS! get the screwdriver out and dislodge it.. stay away from gravel..
Every rotation you here the rock smack the cement!! unless your in grass... then it could be ball joints...LOL
(pointing out the obvious)
Chili
Old 09-21-2010, 04:32 PM
Trim Level: Fleet
Rep:47
Yeah, could be a nail or screw stuck in the tire...OUCH!
