Old 10-20-2009, 08:25 PM
edgeracing edgeracing is offline
Vehicle: 02 Dodge Ram 4x4 SLT
Color: RED
edgeracing is on a distinguished road
Default 02 4x4 front wheel bearing replacement
I have 02 4x4 that has a front wheel bearing failing. In my research here, there is not much detail in replacing the bearings, just a bit on how to remove the hub. Is it necessary to replace the whole Hub? Can the bearings be pressed out and replaced, and if so does anyone have the replacement bearing numbers?
As I live in Canada, we seem to pay a premium for parts. I have seen complete hubs for the ram from $120.00 to $250.00 from various US sources, but here in Canada that same hub is $466.00. Importing is slightly cheaper but brokerage fees can be painful.
Old 10-20-2009, 09:55 PM
Never tried replacing the bearing in the hub . Only way I've ever replaced them is by buying the whole hub assembly . If you can get it apart , you should be able to get the number of the bearing .
Old 10-20-2009, 11:10 PM
warbat warbat is offline
Vehicle: 2002 Ram 1500 4x4
warbat is on a distinguished road
i replaced both of my front hubs yesterday and the day before. I do not believe you can get just the bearing, or atleast i was unable to find them. i called and searched everywhere and always came to the same conclusion that the whole hub assembly has to be replaced.
its not a bad job BUT have a big hammer ready. no joke it took at least 3 hours per hub to beat the darn thing out of the spindle. It was a nightmare stupid dodge put steel hubs on aluminum spindles. they sorta melt together and getting them apart without destroying the spindle means you gotta hammer that bastard off. IT SUCKS. my body feels like i was in a car wreck.
do yourself a favor and rent a wheel puller. it wont get much off but you can use it to push your drive axle in. It makes getting the 3 bolts that hold the hubs on much much much easier to get.
Old 10-21-2009, 08:33 AM
Color: RED
As soon as I get the boat trailer tucked away for the winter, I will get it apart and see if can source just the bearings. I will let you all know how I make out. Thanks for your replies.
Old 10-21-2009, 07:45 PM
MRRMX MRRMX is offline
Vehicle: 2007 Ram Quad cab 4x4
Color: grey
Rep:12
MRRMX is on a distinguished road
I did on my blazer wheel bearings...bought the cheapest and they had only 90 day warranty on them....6 months and they were shot...... saved like 50bucks each up front ...but I would have spent a whole lot more the second time..... buy quality....
Old 02-02-2011, 10:29 PM
barch69 barch69 is offline
Vehicle: 2003 Dodge Ram 1500 4x4
barch69 is on a distinguished road
What size socket is needed for the axle nut?
Old 02-23-2011, 11:00 PM
nocoborn's Avatar
nocoborn nocoborn is offline
Vehicle: 2004 Dodge Ram 4x4 Qd Cab
nocoborn is on a distinguished road
This is a little late, but mine was 36mm.
