Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-08-2010, 10:51 AM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
Default AC leaking into passenger floorboard
Hi all, newbie here. I wanted to pass on a problem I had with my AC. It was leaking into the passenger floorboard but I couldnt find a leak. After searching on here a little bit, I found some info that helped out. Turns out the leak was from the drain that protrudes thru the firewall. I thought it was the air box at first but the water was coming out of the drain and ran back to the firewall. I believe is seeped thru the firewall seal and into the cab. Once I put a hose on the drain, problem gone! Just wanted to pass this on to everyone in case they come across it. I love the board, great info!
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 09-09-2010, 10:35 AM
Rep:1625
Old 09-09-2010, 11:25 AM
iRESQu iRESQu is offline
Rep:2217
Thank you for your help! REPS for that! I also noticed this is your first post, be sure to stop by the "newbie" section to introduce yourself and receive your fair share of harassment!
Old 09-09-2010, 11:57 AM
Vehicle: 2001 Ram
Color: Blue
Rep:23
Will do, thanks! Just picked up a little tidbit on here again and fixed another issue on my truck. Great forum!!
Old 09-09-2010, 03:34 PM
Rep:4072
Thanks for passing along the info and glad to hear you're finding the site helpful! Nice to be able to find and share the info you need!
Old 08-09-2011, 12:04 PM
BroncoLee BroncoLee is offline
Vehicle: 1996 Dodge Ram 1500
BroncoLee is on a distinguished road
I'm having the same problem. I'm not sure where this drain is though, any help or pics?
Thanks!
Lee
Old 08-09-2011, 02:10 PM
I found it, little black nipple sticking through the firewall underneath the accumulator/drier on the passenger's firewall. It's kind of hard to see but you can easily find it by feeling along the wall with your hand under the drier. I used a 1 foot piece of 5/8" inside diameter, 3/4" outside diameter hose and a hose clamp. This keeps the water from weeping into the cab between the metal and plastic housing and making it to the floorboard.
http://s1098.photobucket.com/albums/...t=airdrain.jpg
Old 08-09-2011, 07:41 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
BroncoLee,
Glad you found it and you hit the nail on the head! It bugged me a lot thinking I was going to have to take the dash out and replace the evap. Thankfully it was a simple fix and like you said, a foot of hose and a clamp!
Old 08-11-2011, 11:27 AM
Yeah, can't really beat this fix with a stick, so darn easy and it only costs a couple bux.
