door panel removal tutorial - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-08-2010, 04:24 PM
firelt firelt is offline
Vehicle: 2010 Ram 1500
Trim Level: Bighorn SLT
Color: Dark gray
Rep:83
firelt will become famous soon enough
Default door panel removal tutorial
I know its simple but since I did it today on all my doors to paint the handles I figured I would take some shots and share with you all!
First take the screws out of the edges of the door panel, they are torx screws into a body clip. Then remove the screw that holds the plate behind the door handle on ( there is a screw cover that pry's off to reveal the screw). Once all these are off pry the panel outward where each of the torx screws had been, be warned the body clips come sprining out so put a finger on them or they fly away The red dots in the below shot show the locations, front doors have one extra screw on the bottom.
Next pry the cover behind the door handle off gently. You can also pull the switch plates out by prying where the plastic meets the door panel material. You could leave them on but I found it easier to disconnect the wire this way than waiting untill I pulled the panel off.
You should now be ready to remove the panel. Lift up on the panel and pull it out. There is a trim piece on the top coming down the post that simply prys off. The rear stays on the door but the one on the front door can come off completly or stay on on the panel once its gently pried.
If you choose not to remove the switch plate from the panel be warned the wires are held in place by a clip. Remove the wires from this clip and its much easier to unhook them from the switch.
And now you should have the panel off for whatever your need is!
Hope this helps someone, Ill post pics of the painted door handles when they are done and wet sanded, may be a week or two though.
Old 09-08-2010, 04:37 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Nice write up, rep for that!
Old 09-08-2010, 04:42 PM
Rep:4376
I agree, very nice write up, should prove useful to many folks on here!
Old 09-08-2010, 05:18 PM
Rep:1625
Very nice writeup!!
Old 09-08-2010, 05:21 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Nice write up, pics help a lot.
Brian:
Old 09-08-2010, 06:13 PM
Color: Dark gray
Rep:83
Thanks everyone, figured ive stolen enough ideas in the last week, time to give back what I can!
Old 09-08-2010, 06:23 PM
Mikeal007 Mikeal007 is offline
Vehicle: 2014 5.7 2500 Crew
Mikeal007 is on a distinguished road
Removing the damn thing is easy. Putting it back on was the real bitch.
Old 09-08-2010, 07:03 PM
Color: Dark gray
Rep:83
mine just dropped back on, was by far the easiest door ive ever dealt with. Just line it up on the left and right, but about 1"-2" higher tahn it should be and apply gentle pressure as lowering it back onto the hooks. after that the little plastic body clips and screws on the outer ring just get pushed back in and screwed down. Was your set up like mine or a different model?
Old 09-08-2010, 07:10 PM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Nice job with the write up.
Old 09-08-2010, 09:39 PM
Rep:3347
Great write up for the '10
