Old 09-08-2010, 08:35 PM
tmwood72 tmwood72 is offline
tmwood72 is on a distinguished road
Default P0306 Problem
This has been driving me nuts. I hav been coming up with an 0306 DTC and sometimes a random order misfire 0300 and 0308. I have replaced everything, the cat, plugs, wires (8.5mm with convolute) rotor, crank sensor, cam sensor, MAP, IAC, Injectors and O2 Sensors, you name it I changed it and I keep coming up with these codes. Mostly the 0306 code which I know they are the #6 and #8 cylinders. I also did the TSB for the wire routing and nothing seems to work. Could this be a problem in PCM? Any suggestions would help. I am going crazy here. The truck is 1997 ram 2500 4x4 5.9 liter with the VIN of "Z". I also checked the compression and it is fine on all cylinders. Please tell me there is someone out there that can help.......
Old 09-08-2010, 10:40 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
might be the ecm :/
Old 09-09-2010, 01:20 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Look into your intake and see if there is any oil. Could be a blown plenum gasket. Are you using any oil?
Old 09-09-2010, 05:08 PM
Default ECM and Plenum
I will try the Plenum check first for oil then I think the ECM will be last resort. One stupid question on the plenum gasket check. How do I look into the plenum? Thru the throttle body? Will I see oil right in there?
Old 09-09-2010, 06:46 PM
DEANTHECRABMAN. I looked down thru the throttle body and had seen an oily residue at the bottom of the intake. But I am not using any oil. Is this common? Would this destroy the O2 sensor after the cat as well? I am not blowing any smoke at all. This has driven me nuts for over a month now.
Old 09-09-2010, 07:17 PM
Rep:1845
You'll have residue in the intake anyway from the PCV system. You need to check it with a vacuum gauge.
Old 09-11-2010, 04:22 PM
Color: Garnet red
Rep:202
Here's how. Credit to RamTech for posting this.
http://ramforumz.com/showthread.php?...gnostic+plenum
Old 09-11-2010, 10:48 PM
DaveDees's Avatar
DaveDees DaveDees is offline
Vehicle: 2010 Jeep Patriot
Trim Level: Latitude
Rep:40
DaveDees is on a distinguished road
Causes
A code P0306 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Running out of fuel
  • Poor compression
  • Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back. If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
All articles that coruscate with resplendence are not truly auriferous.
Old 09-14-2010, 07:58 PM
Default Thanks DaveDees
I tried all of what you said with the exception of the PCM. I think this maybe my last resort. How do I test vacuum from the plenum to see if it is OK?
