Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 01-10-2011, 08:54 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
actually its very easy to use, GPS based. Get that 60ft down a lil more youll see a big improvement
Old 01-13-2011, 10:22 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
As posted prior:
60 ft. 2.25 sec @ 30 mph
330 ft. 6.18 sec @ 59 mph
1/8th 9.39 @ 81 mph
1000 ft 12.06 sec @ 90 mph
1/4 14.37 @ 97 mph
Today, about 35 degrees, truck was driven about 5+ miles, fluids had not yet reached full operating temp. ESP switched to off, feathered throttle a bit on take off to avoid spinning,,, 91 tune
Well, feathering and ESP 'off' didn't change a thing, but,,,
1/8th 9.24 @ 82 mph
1000 ft 11.91 sec @ 92 mph
1/4 14.16 @ 99 mph
Hmm, somethin musta 'woke up' at/past the 1/8th mark,,,
Can't really take data-logging as 'pure fact', but theres a fair amount of difference between today and 12 days ago when I ran 14.63 @ 96,,, (60 degrees F. SC 87 tune)
Old 01-14-2011, 04:18 PM
autobred's Avatar
Trim Level: R/T
Rep:142
30 degrees is a big difference. Look it up in dragtimes da calculator and punch in the nearest racetrack to you to see what was the difference in days and correct them. You should be able to find your answer in there
Old 01-19-2011, 12:46 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
60': 2.93sec
330': 6.76sec
1/8mile,660': 9.90sec@ 80.4mph
1000': 12.56sec
1/4mile,1320':14.78sec@ 102.6mph
spun all of first but this is the best pass so far......suspect the mph would go down if the 60' and ET went down......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 01-19-2011, 07:19 AM
autobred's Avatar
Trim Level: R/T
Rep:142
awesome trap did you manually shift or just let her rip? Thats easily a low 14s truck with a better hookup.
Old 01-20-2011, 05:25 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
thanks buddy.....left it in drive....only had time for a couple passes....but once i cure the traction issue ill play with manually shifting....yeah i didnt expect that trap either!
Old 02-04-2011, 04:20 PM
440ram 440ram is offline
Vehicle: 1988 Dodge LS1 Ram
Rep:36
440ram is on a distinguished road
Add mine, 14.05 @ 94 1988 LS1 Dodge Ram N/A
motor is a 1998 corvette 5.7l LS1 4l60e trans np208
1988 LS1 Dodge Ram
Old 02-04-2011, 07:14 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I can't wait to get some runs down the track this spring. Hoping to run at least high 13's not sure if il be one of the first fourth gen crew cab's or not. Or crew cabs period.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-06-2011, 11:43 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
wow not bad.....just imagine what it would do if you put a hemi in it.....
Old 02-13-2011, 08:02 AM
autobred's Avatar
Trim Level: R/T
Rep:142
thanks for vid, nice run. The modern legendary LS1, thats the first year chevy made it correct? Tons of aftermarket for that motor.
