Replacing rear power window on 2010 - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 09-12-2010, 02:07 PM
Originally Posted by HoustonHemi View Post
One of the 'oddities' of this forum that you'll seldom see elsewhere,,, threads get moved by the Mods on a regular basis.
Never did understand the 'click on the new posts tab instead' rationality,,,.
(And I still don't use it.)
Myself, I don't really want to sift through a bunch of new posts covering a barrel full subjects that I have no interest in....
BUT, sorry for the OT rant.
We don't move the threads . Their cycled through the system automatically . The only time we move them is if they were started in the wrong section . Then we send a pm to the originator of the thread and we tell them that we moved it to a new location .
Old 09-12-2010, 03:10 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
There are 2 ways to find a post you made.
1. Click on "search" then "advanced search" then type in your name and hit enter.
2. Click on your name in any thread and then click "find posts all posts".
Brian:
Old 09-12-2010, 04:50 PM
LARAMIE382's Avatar
LARAMIE382 LARAMIE382 is offline
Vehicle: 2010 DODGE RAM
Trim Level: LARAMIE CREW CAB
Color: BRILLIANT BLACK
Rep:25
LARAMIE382 is on a distinguished road
Send a message via Yahoo to LARAMIE382
Originally Posted by moparornocar72 View Post
First off that sucks your truck got brokin into. Sounds like a gang initation as thats what the stupid gangs to around here. Here's what I could come up with. let me know if you need more and I might can dig up some more.
  1. Slide the upper run channel (1) out of the window frame (2).
  2. Slide the vent glass (3) upward to remove from the lower window frame (2).
  3. Lower the glass (3) out of the upper window frame (2) and remove.
THNX SO MUCH. now that works for a manuel window. got the window in place. now i have to put the cables on each side of it for it to be able to close and open. now how do i realese the cables from the old window frame. i mean how do i get some slack out of them to be able to pull them out.
Old 09-12-2010, 05:08 PM
LARAMIE382's Avatar
Rep:25
So what specifically do you need help with. Sounds like you are halfway there.
all i need now is how to release or get some slack from thecables that run to the motor. how do i remove the old window frame (thin piece of plastic, has a cable on each side, push and pull i guess
Old 09-12-2010, 06:08 PM
LARAMIE382's Avatar
Rep:25
THANX AGAIN FOR ALL THE HELP.
Old 09-12-2010, 06:42 PM
moparornocar72's Avatar
Rep:630
laramie did my info not help at all? cajun posted the two (yourold and new) together. Let me know if not I might can come up with some more info.
14.268 @ 95 MPH Full Trim
Old 09-12-2010, 06:44 PM
Rep:630
sorry didnt seer the second page, did u figure it out?
Old 09-12-2010, 06:50 PM
Rep:630
  1. Remove the 2 mounting bolts (1).
  2. Disconnect the electrical connector to the power motor.
  3. Rotate the assembly and remove the 3 screws (1) that attach the motor to the regulator.
Old 09-12-2010, 06:54 PM
Rep:630
Sorry left this out.
Separate the cable housings from the glass track (1).
Disconnect the cable ends from the vent glass (2).
Separate the support clips (5) and remove the regulator assembly (3).
Old 09-12-2010, 10:24 PM
LARAMIE382's Avatar
Rep:25
WOW thanx. this wouldve made it a lot easier but i got it. you know those two black pins with the gold springs tha tattach to the motors (cables) push those two in (like your grasping it) and theres your slack. no need to remove those pins from the track, which i couldnt anyway. there like glued in there or something i didnt want to break them. but in the future for anyone else. allyou do is remove the back seats (no headliner), slide out that upper track and push those pins together nad voula (probly didnt spell that right) but you get the poin. thanx again for all the help
