Fuel Fill Nozzle Shuts Off - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Diesel Forums!
Dodge Caliber
Old 01-02-2010, 07:40 PM
Rep:1915
Post Fuel Fill Nozzle Shuts Off
TSB 14-001-09 REV A
NOTE: This bulletin applies to all vehicles equipped with a gasoline engine.
DISCUSSION:
Customer may report that the vehicle is hard to fill with fuel or that the fuel pump nozzle shuts off repeatedly while trying to fill vehicle.
This customer complaint can occur due to a number of different causes. The fuel tank is the least likely cause of this condition.
The following Diagnostic procedure can be used to
diagnose the issues.
DIAGNOSIS:
1. Is the vehicle a LX/LE/LC/L2? (300, Challenger, Charger, Magnum)
a. Yes >> proceed to
Step #2
b. No >> proceed to
Step #4
2. Idle the vehicle 60 to 90 seconds upon stopping.
3. Does tank refill properly?
a. No >> proceed to
Step #4
b. Yes >> Inform the customer to idle the vehicle for 60 to 90 seconds upon stopping if vehicle was driven aggressively. This is due to the fact that on the LX/LE/LC/L2 the fuel tank is a unique saddle tank design and needs 30 to 60 seconds while the engine is running to level the fuel in both half's of the fuel tank. Allowing the vehicle to idle for this amount of time will let the fuel pump transfer fuel to the left side tank, opening the control valve and allowing normal fuel filling.
4. Disconnect the vapor recirculation tube at the fuel tank.
5. Attempt to refill fuel tank.
6. Does tank refill properly?
a. Yes >> Proceed to
Step #7
b. No>> Proceed to
Step #11.
7. Reconnect the vapor recirculation tube at the fuel tank.
8. Disconnect the other end of the vapor recirculation tube at the fuel filler tube.
9. Attempt to refill fuel tank.
10. Does tank refill properly?
a. Yes >> Replace fuel filler tube.
b. No >> Replace the vapor recirculation tube.
11. Disconnect the control valve to EVAP canister tube at the fuel tank.
12. Reconnect the vapor recirculation tube at the fuel tank.
13. Does tank refill properly?
a. No >> Replace Fuel Tank.
b. Yes >> Proceed to
Step #14.
14. Reconnect the control valve to EVAP canister tube at the fuel tank.
15. Disconnect the control valve to EVAP canister tube at the EVAP canister.
16. Attempt to refill fuel tank.
17. Does tank refill properly?
a. Yes >> Blockage is in the EVAP Canister, or ESIM, or Clean air hose (ESIM vent hose), or filter. Diagnose appropriately.
b. No >> Replace the control valve to EVAP canister tube.
Old 01-03-2010, 01:40 AM
MightyBlueRam's Avatar
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
Thanks for posting this information Randy!
Old 01-03-2010, 03:35 AM
Rep:3347
Thanks a lot Randy, there's been lots of questions about this.
Old 11-22-2013, 10:22 PM
trackman trackman is offline
Vehicle: 2009 dodge ram 2500
Color: red
trackman is on a distinguished road
Thanks Randy! Can't even think of replaceing the fuel tank. Looks like Dodge needs to do a recall on there tanks or something. Four years old an 26000 mile doesn't look good for Dodge business. I am going for a hip replacement on the 25th of this month so it will set untill I hear back from them. Will let you all know when I do.
