Smashed the Door - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 09-10-2010, 10:29 AM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Smashed the Door
So i went to pick my truck up the other day from the Dealership cause it needed the heater core replaced...it was rather windy that day...me being dumb i decided to open the driver door and then the ext cab door to put my stuff in...as i turned to put my stuff in the back the wind caught the front door and threw it completely open and smashed it into the service truck next to me! I checked their truck and saw there was no damage but when i checked mine it had completely split the paint and it was flaking off! I picked some of the flakes off and sanded it down but the door is completely exposed to the elements...should i get some touch up paint and cover it? Bondo it? Prime it? Any suggestions woudl be greatly appreciated...
Old 09-10-2010, 10:43 AM
If there are no dents then leave the bondo alone. I would suggest you sand down, primer and paint the area.
How big of an area is affected? You'll want to make sure you go past the area that is cracked and flaking when you sand otherwise it will crack through the new paint. You gotta chase down the crack and eliminate it before you paint.
Old 09-10-2010, 11:01 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
good advice Michael
Brian:
Old 09-10-2010, 11:08 AM
alfonso318's Avatar
Rep:42
Yah i think the area was only about 2 or 4 inches and i went past it both directions...what kind of paint should i use? I'm thinking spray paint will be a mess...
Old 09-10-2010, 11:21 AM
You can get paint that matches your color, and clear coat as well, in a rattle can that works pretty good. Check out paintworldinc.com
