Old 09-11-2010, 12:00 AM
leadfarmer420's Avatar
leadfarmer420 leadfarmer420 is offline
Vehicle: 04 Ram 1500 4x4
Trim Level: none
Color: charcoal
leadfarmer420 is on a distinguished road
Default electric fan question
Is there any advantage in running two e fans? If so what? I was told that i could run one to push and the other to pull.
Old 09-11-2010, 12:30 AM
I push the skinny pedal
Rep:3308
Absolutely you can, just be aware of having the flow restrictions caused by having the fan in front and the potential of not cooling the outside fins properly. I'd recommend a single puller fan rather than two myself UNLESS you have a track only drag truck and need to cool it properly with no airflow.
Ive got a single electric fan and I've NEVER had my temps come up over 50% on the guage, even pushing it hard through the mountains
Kurtis
Old 09-11-2010, 12:47 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Pros and cons to both.
As CdnoilRAM pointed out, having a fan in front of the rad restricts some of the air flow, so if your cooling system is at near capacity, could case issues. For maximum cooling efficiency, a single fan that is properly sized for your rad will be about the best way to go.
However, 'WHEN' your electric fan quits, the second fan (if you have it) will at least provide you with some cooling, likely enough to get you to where you need to go to get it repaired.
So....pros and cons to both setups. If I were to do this mod, I would do the single fan setup that CdnoilRAM has done......but I would carry a spare fan motor under the back seat. (I don't do tow trucks!)
brad
Interested in one of my mods?
