low and high, driver side lights out - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 09-11-2010, 02:29 AM
longbow longbow is offline
Vehicle: 2012 Dodge Ram 1500
Color: Molton Red and Silver
Rep:37
longbow is on a distinguished road
Question low and high, driver side lights out
Need help here. Changed out my bulbs to Piaa's when I bought my truck last year, no problem and just recently the driver side stopped working ,so I removed the light assembly checked the bulbs they are OK and put them back in a the thing lights up , Today coming home , there out again ??
Any thoughts or Ideas ????
Old 09-11-2010, 08:37 AM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
Hopefully someone will be along shortly who can answer this, so I moved it here so those that can help will see it.
Old 09-11-2010, 08:51 AM
Resident Technician
Rep:1915
It's under warranty. Let the dealership take a look at it and find out where you're losing voltage.
Old 09-14-2010, 08:35 PM
Rep:37
Thumbs up Problem solved
So it was the TIPM, was faulty (whatever that is some type of controller) covered under warranty , .
Odd that when I disconnected the neg battery terminal the lamp would work for a few days then it would stop.
Thanks for the heads up Ram Tech,( mentioned this on my previous post) .
