Old 09-11-2010, 09:01 PM
kmarshall32 kmarshall32 is offline
kmarshall32 is on a distinguished road
Question Need FAST help!! Noob question!!!
Hey guys I just bought a 2000 dodge ram 1500 with a 5.9 in it, the doghouse was off the truck and I just got it together, well I have a really dumb question (I assume it's dumb...) How do the transmission lines run? Do they just run to the aluminum cooler or to the radiator then the cooler??? I know it's probably a pretty dumb question, just soooo close to getting it done before it gets dark and can't find it anywhere... some one please, please help fast!!
thanks in advance!
Old 09-11-2010, 11:08 PM
arghhhhhh.
Old 09-11-2010, 11:57 PM
I push the skinny pedal
Rep:3277
Kurtis
Old 09-12-2010, 12:27 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I would expect them to run to the trans cooler section of the rad, then to an external cooler if you have one. Although it has been brought to my attention more than once that technology has changed a few things in the decade+, I am unaware of the trans cooler system changing much. If you have cooler line fittings on the bottom (or side) of the rad, and an external cooler, then I would say trans output to rad, then to cooler and return to trans. Might be out to lunch, but this is how I did it for years on older (pre 95) vehicles with excellent results.
brad
Interested in one of my mods?
Old 09-12-2010, 01:03 AM
I can check mine tomorrow and get back to ya .
Old 09-15-2010, 12:14 AM
well got that figured out... but now, I drove it to work, and on the way home the voltage gauge dropped all of a sudden (not slow) so I thought the battery cable fell off, i tightened the connections and had to jump it, and now it wont stay running... guessing alternator quit all at once, theres no other voltage regulator, correct?
Old 09-15-2010, 12:51 AM
Airborn3's Avatar
Airborn3 Airborn3 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SS/T
Color: Black w/ Silver
Rep:46
Airborn3 is on a distinguished road
Send a message via MSN to Airborn3
Correct. My alternator did the same thing. No warning just BAM! died.
'98 Ram SS/T
Magnaflow exhaust, CAI, Aftermarket headlights and fog lights with HID's, L.E.D. Taillights, Blue L.E.D. interior lights, 2" drop on the rear, 2.5% tint on side and back window.
Old 09-15-2010, 01:50 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Just to be sure, when you say it won't stay running, is that at idle? Its entirely possible for a dead battery to be the problem if it won't idle.
Best to get both the battery and alternator tested before you spend the $$, if you can get to Autozone or the like.
Brian:
Old 09-16-2010, 01:32 AM
I took both in and had them tested, does the black wire from the alternator run to the fuse box or is it ground? lmao...
