Old 09-11-2010, 09:15 PM
98goatfarmer 98goatfarmer is offline
98goatfarmer is on a distinguished road
Default Engine has problem idling?!?! HELP!!!
Well today I hopped in the truck to fire it up. And it started up just fine, but almost immediatley it almost died. and i mean it went down to like.. 100-200 RPMS and then slowly idled its way back up to normal idle which as around 600-700ish.
I think its either a MAP or a TPS sensor, but can any one clarify this for me!??
PLEASE HURRY!!
Old 09-11-2010, 09:25 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Is your check engine light on? If so, go to Autozone or the like and have them pull all the codes. They can't reset it, but can tell you what's what.
Brian:
Old 09-11-2010, 09:29 PM
Rep:1845
Either could still give problems similar to what you described without throwing codes.
Old 09-13-2010, 02:41 PM
bigiron's Avatar
bigiron bigiron is offline
Vehicle: 2001 RAM 2500
Color: WHITE
bigiron is on a distinguished road
I just changed my crank position sensor for the same symptom. Just keep it in mind if the other fixes dont work
Freedom is not free, but the U.S. Marine Corps will pay most of your share.
Old 09-19-2010, 10:35 PM
Meyster89's Avatar
Meyster89 Meyster89 is offline
Vehicle: 1998 Dodge Ram 5.9 4x4
Meyster89 is on a distinguished road
I had the same issue, changed sensors and nothing. had the battery checked out and autozone said it was good. took it too a shop and they said my battery was shot, so i put a new battery in and it runs great!! check your battery! i never would have thought this to be the problem, so i didnt change it out right away, but once i did, my truck idles better than the day i got it and took care of my problems.
Old 09-20-2010, 12:16 AM
Have you ever cleaned your throttle body ?
