Old 09-15-2010, 11:41 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
damm stealerships
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-04-2010, 01:36 AM
groovydawg's Avatar
groovydawg groovydawg is offline
Vehicle: 2004 Dodge Ram 1500 Hemi 5.7L
Trim Level: Quad BigHornEdition
groovydawg is on a distinguished road
hello i'm new here,
1) My 2004 Ram 1500 Hemi, had MIL came on 1st, code pulled and EGR was replaced. That solved the MIL issue.
2) next day the ETC light came on solid, PPS & MAP Sensor replaced.
3) next the ETC light was blinking, other parts replaced-and the Throttle Body was replaced.
4) seemed to be good until driving approx 30 miles, ETC light blinking again. Then a wiring harness was found to have a short. It was "repaired" then taken to Dodge dealer to reset on computer.
5) This time it was driven approx 70-100 miles with no problems. That was on Tuesday Nov 02. Today Wed, after driving 15 miles, I felt a "slight" loss of power, then ETC light came on "blinking" again. Turned off engine and restarted. ETC light was "off". Drove home after work approx 20 miles, no ETC lights. No problems.
***WHAT is the next step? This is a "recurring" problem for several others. I love my truck and don't want to get rid of it.
Can't Dodge and any others come up with a sure fix???
Sorry so winded, but getting frustrated.
thanks in advance...!!!
Old 11-04-2010, 10:45 AM
Cammin Hemi's Avatar
Cammin Hemi Cammin Hemi is offline
Vehicle: 2014 Ram R/T
Trim Level: RT
Color: Blue Streak Pearl
Rep:18
Cammin Hemi is on a distinguished road
What p-codes are you getting now? Are you running a stock tune? When it's running does it run smooth? Is the idle speed the same? A vacumme leak could be the problem.
2004 Dodge Hemi standard cab short bed "gone but not forgotten".
Old 11-05-2010, 12:18 AM
groovydawg's Avatar
Thumbs up
thanks for reply Cammin Hemi,
P code today was 2138
Had it checked at a friends shop. He mentioned Throttle Control(?) and dealer Re-Flash.
The other shop before said had replaced the Throttle Body and the next day was when the ETC light started "blinking again. Then they found the short in wiring harness and said they repaired it. Then was going to take to a Dodge dealer for the re-flash or re-set (whatever it's called). Waiting to get list of what all was done over a 5-6 day period. I will post list when i get it for more reference.
All stock no add ons yet. It runs smoothly as normal and idle is normal. The last 2 days after the last ETC light "blinked", driving approx 50-60 miles, "no ETC light ups or blinks". All normal performance.
I forgot to mention last nite that my truck has 177k plus miles. And runs surprisingly smooth and powerful.
I will ask about vac leak, but running smoothly for now, so not acting like a vac leak.
Thanks again, any info will be helpful!!!
Old 11-05-2010, 12:32 AM
Trim Level: st
Color: silver
Rep:68
Originally Posted by Daytona1445 View Post
unless he is over 70k miles his 05 should still be in warranty at least for some stuff.
The 05's came with the 7/70 warranty.
Ha i wish that work with me
Old 11-05-2010, 10:46 AM
Trim Level: RT
Rep:18
Code p2138 is for throttle pedal position. The flash at a dealer will relearn your new throttle body as far as pedal position at wot, idle and everything in between.
Old 11-05-2010, 11:47 AM
Resident Technician
Rep:1909
Possible causes for P2138 -
EXCESSIVE RESISTANCE IN THE (F855) 5-VOLT SUPPLY CIRCUIT
EXCESSIVE RESISTANCE IN THE (F856) 5-VOLT SUPPLY CIRCUIT
EXCESSIVE RESISTANCE IN THE (K167) SENSOR NO.1 RETURN CIRCUIT
EXCESSIVE RESISTANCE IN THE (K400) SENSOR NO.2 RETURN CIRCUIT
EXCESSIVE RESISTANCE IN THE (K23) APP SENSOR NO.1 SIGNAL CIRCUIT
EXCESSIVE RESISTANCE IN THE (K29) APP SENSOR NO.2 SIGNAL CIRCUIT
APP SENSOR
PCM
Old 11-05-2010, 11:50 AM
Resident Technician
Rep:1909
The dealer is splicing a harness? not sure i would trust that repair. I would think that the dealer would only replace the entire harness.
maybe the hours of hunting and poking at wires puts more money in their pocket. either way something isn't right about it.
Nothing wrong with a splice as a repair if it's done correctly. Factory harnesses have a lot of splices in them to begin with.
