Old 09-12-2010, 11:58 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
Default 2009-2010 Dodge Ram (Alpine) Amp Wiring Diagram
Just in case anyone needs it here's the diagram for our trucks for all the speakers. DG is Dark Green, GY Is Grey, Yel is Yellow, LV is Lavender.
Don't mind my sloppy notes on the diagram. This diagram came from ALL DATA by the way.
Old 09-13-2010, 03:42 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
ok and in a mans world lavender is what color....? lol isnt that a smell or flavour?
DODGE the father RAM the daughter!
Old 09-13-2010, 04:18 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
It's the color on the face of those ricers when we blow right by them
Old 09-23-2010, 02:36 PM
jaynuke jaynuke is offline
Vehicle: 2013 Ram 2500 5.7L
Trim Level: Lone Star
Rep:14
jaynuke is on a distinguished road
Would the colors be the same for the non-alpine models?
Thanks
Old 09-24-2010, 04:54 PM
Rep:61
Don't quote me on this but two different people I spoke to stated the wiring colors are the same on the NON Alpine models, but the polarity is reversed on the Non-Alpine models....meaning that say the Passenger side Dark Green wire with yellow stripe would be POSITIVE, and the Dark Green stripe with Lavender/Purple would be NEGATIVE.
As you can see on the diagram, the wire colors for the Alpine model are the same, but the Lavender is POSITIVE while the Yellow is NEGATIVE.
Old 09-24-2010, 04:59 PM
Rep:2620
There is a website that everyone should bookmark, it has the wiring setup, BUT, no images
for
Car Stereo Wiring Diagrams, Car Alarm Wiring Diagrams, Remote Start Wiring Diagrams, Car Light Bulb Size Guides
http://www.modifiedlife.com/
Old 03-13-2011, 06:33 PM
kozzy kozzy is offline
Vehicle: 2014 Ram 2500 Outdoorsman
Trim Level: Outdoorsman
kozzy is on a distinguished road
yes, that is correctr i have the non alpine system and recently installed all new gear, the wire colors were the same, but the poliarity was opp. the alpine system.
Old 03-17-2011, 10:26 AM
Juswaymac Juswaymac is offline
Vehicle: 2010 dodge ram 3500
Trim Level: Slt
Juswaymac is on a distinguished road
I have the Alpine system in my truck and want to add aftermarket amp and subs but keep the other speakers and nav head unit. Is just adding the rca line out converter OK? If so, is a simple model good or is there a premium model that needs to be used? Any tips would be appreciated.
Old 03-23-2011, 02:36 PM
Slowburn Slowburn is offline
Vehicle: 2009 Dodge Ram CrewCab
Slowburn is on a distinguished road
i have the same exact question
Old 03-30-2011, 02:47 PM
Rep:61
Jared (Dodgeman) can answer this question best but from my understanding our Ram's only give a full range signal to THE FRONT DOOR SPEAKERS. That full range signal is 20hz-20khz so those front speakers HAVE to be Tapped in order to get the full range signal. The dash and rear speakers only produce signals in specific ranges/frequencies so you can't tap them or you'll get no bass. I've learned a lot from members on this forum and the basis of this is that you can use a LOC, but you still need to tap to get that full range signal from the front doors, one way or the other.
The stock Alpine speakers are pretty bad..no real clarity with mids or highs so not sure why you would want to keep them, but either way you'll still need to get that full range signal to your aftermarket amp no matter what route you go. Good luck.
