Old 09-13-2010, 10:34 AM
Jacksback's Avatar
Jacksback Jacksback is offline
Vehicle: 2004 Dodge Ram Quad 5.7 Hemi
Jacksback is on a distinguished road
Question 2004 Dodge Ram Heating Problem
Hi, I have an 04 ram with little to no heat. (This Ram has the individual heat controls for driver/passenger)
-Ac works great.
- the interior heat gauge shows the needle just before the halfway mark between cold/hot
-the two hoses going into the heater core are both hot to the touch
-Fan works no problem...as well the air blows string to all areas you select on the fan control.
-I changed the thermostat...no luck
-I flushed the rad and replaced with new factory spec fluids...no luck!
-Temperature control unit seems to work turning on/off the AC, adjusting fan speeds, location of air flow,rear defrost....however the little indicator lights above the AC/RD and air ciculation do not switch on.
Any Ideas?
Cheers Shane
Old 09-13-2010, 06:16 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Sorry Shane cant help. Iam replying to get this up front for you. Best of luck.
Old 09-15-2010, 04:38 PM
Jacksback's Avatar
Does anyone think that if I replace the temperature control module that it will fix the problem?
Old 09-15-2010, 04:47 PM
Knowing the problem that these trucks have had with heat/cooling issues , I would venture to say you have a blend air door problem .
Old 10-17-2010, 12:35 AM
rsp919 rsp919 is offline
rsp919 is on a distinguished road
I just picked up a 02 1500 and I am having the exact same problem only my light above the button does come on. Hopefully someone will post a possible solution.
Old 10-17-2010, 01:37 AM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
I too think its a blend door problem...not heat, door is stuck closed.
Old 01-03-2013, 09:41 PM
frenchfox59901 frenchfox59901 is offline
Vehicle: 2004 Dodge Ram 1500 Hemi 4x4
Color: red
frenchfox59901 is on a distinguished road
I have same same problem. How do you un-stick it?
Old 01-03-2013, 10:51 PM
cwiss21 cwiss21 is offline
Vehicle: 2003 Dodge Ram
cwiss21 is on a distinguished road
My guess would be heater core. I replace my heater core in my 2003 today and it was so plugged up! I tried flushing it before to see if it would take care of it but it was just full of rust and crud. Replacing isn't a fun job but if you can do it yourself you can save a lot of money
