Old 09-13-2010, 03:55 PM
teamplus teamplus is offline
teamplus is on a distinguished road
Default Ram 5.2 to 5.9 engine swap!
Can anyone advise me as to the compatibility of this swap out. My current setup is a 1997 1500 magnum 5.2 four wheel drive (receipient) and I am putting a 5.9 out of a 1998 ram (donor).
1) Will the computer have to be changed in the receipient vehicle to match the 5.9 computer?
2) Does it matter if the donor 5.9 is two or four wheel drive from a computer standpoint?
Thank you!
Old 09-13-2010, 04:52 PM
The computer will work . You may have to get it reflashed . The trucks that I have done didn't need to . It doesn't matter if it's 2wd or 4x4 . Just make sure you install the torque convertor for the 5.9 in the trans . The 5.9 is externally balanced .
Old 09-13-2010, 06:56 PM
Thanks for your Help!
Old 09-13-2010, 07:06 PM
Rep:1885
The 5.9 can run on 5.2 software but it's best to have the PCM flashed.
Old 09-14-2010, 08:17 AM
Thank you again. Have a great day!
