Old 09-13-2010, 08:50 PM
09 Hemi 09 Hemi is offline
Rep:14
09 Hemi is on a distinguished road
What's the deal with that? The manual says charging system issue. Its got 22k miles, no problems starting or running. What would make this light turn on?
I took it to autozone to see if it was throwing a code but it came up negative. The voltage gauge was right on the first line on the left. Yesterday I went to pick it up from my wifes work to take it to the dealer and find that the light is off and the volt gauge is in the middle where its supposed to be. If it comes back on ill be taking it to the dealer asap.
Not sure where my original thread went but long story short, 09hemi 22k miles battery light came on and the voltage guage was reading low. Starting having trouble starting it, would make a grinding sound. Took it to the dealer and had the following done, found P2504 charging sys tem output high, excessive resistance in 918 feed circuit (tipm module cable loose). Next issue is transmission makes grinding noise when put into reverse, they found it to be vibration from driveshaft (which I don't think it is) and ordered me a new one. They also performed several recalls on it, HVAC control head reflash, abs module reflash, inspect loose door modling (they scratched my tint!), reseal high mounted brake light (and left the water damaged bulb in it!), inspect and retorqued toe cam bolts. ALL of that in only 22k miles! My next truck will definitly be a Ford....
Old 09-14-2010, 07:10 PM
erik108's Avatar
erik108 erik108 is offline
Vehicle: 2010 slt quad cab
Color: mineral gray
Rep:18
erik108 is on a distinguished road
is the alternator charging ok, ? maybe a loose battery cable ? loose connection
Old 09-14-2010, 07:19 PM
Check and see if it's charging . Should be 13.5 - 14.5 across the battery terminals . NOTE : WARNING : DO NOT REMOVE THE BATTERY CABLES FROM YOUR VEHICLE(S) WHILE RUNNING TO SEE IF IT IS CHARGING . YOU CAN AND WILL DO SEVERE DAMAGE TO THE ELECTRICAL SYSTEM .
Old 09-14-2010, 09:36 PM
moparornocar72's Avatar
Rep:630
If you dont feel like going to the dealership first swing by autozone or advance or w/e you have and let them run a test on it so you know somewhat is going on before going to the dealership, usually the light means the alternator isn't getting enough volts to it or isn't putting out enough. GOOD LUCK!
14.268 @ 95 MPH Full Trim
Old 09-14-2010, 10:00 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^^ What he said ^^^^^^ The light will come on when the alternator fails to put out enough current to maintain a charge on the battary. Sounds unusual for an 09 with only 22k on it.
Old 09-16-2010, 12:47 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Vehicle: 2009 Dodge Ram
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
Could even be a bad battery tempature sensor.
Old 09-16-2010, 03:47 PM
Rep:1909
According to the diagrams I'm looking at, battery temp sensors are no longer used. I haven't taken the battery out of a DS so I can't say this with 100% certainty.
