Old 09-13-2010, 11:32 PM
Rogers Rams's Avatar
Rogers Rams Rogers Rams is offline
Rogers Rams is on a distinguished road
Default Keyless Entry?
My factory keyless entry sucks! If i'm not standing right next to the vehicle it barely works.....I had a dodge charger before i got the Ram and the keyless entry on the charger worked from damn near anywhere on the planet! I could lock my doors from inside of buildings & everything. But the keyless entry on my Ram sucks really really bad. The dealer programed me a new one and that one sucks also. They told me it was nothing else they could do, call Chyrsler and complain about it........Have anyone else had this problem with their factory keyless entry?(I have to actually point the key at the truck like i'm using a tv remote)>_<
Old 09-13-2010, 11:37 PM
Jim Ram's Avatar
Jim Ram Jim Ram is offline
Vehicle: 2010 Ram 1500
Jim Ram is on a distinguished road
I can use the remote start of mine 100 yards away and it works....maybe they keep giving you bad batteries?
2010 Ram 1500 Navigation
2007 Accord EX V6 Navigation
Old 09-13-2010, 11:50 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I have found with mine, that it is consistently, inconsistent!
Most of the time, it works great...but every once in a while, it doesn't appear to work while I'm standing at the truck with my hand on the door trying to unlock it.
What I have been doing recently, is to press the buttons slowly and deliberately and holding it for a good second. I have notice a much improved success rate.
One thing that is very consistent. Every time I pickup a large heavy item, like a large speaker box, the remote start works!
brad
Interested in one of my mods?
Old 09-13-2010, 11:54 PM
Jim Ram's Avatar
One time while walking in to my house the remote start started the truck. I guess I have too many keys on my keychain, I had to eliminate a few and the problem seems to have gone away.
Old 09-14-2010, 12:01 AM
brad12kx's Avatar
Rep:2581
Just after I got mine, I was installing the tailgate lock, climbed under the truck to run the wiring along the frame, and while adjusting my position on the creeper, the truck started. Yup....Brown everywhere!
Now when I work on the truck, I have either the hood or a door open.
brad
Old 09-14-2010, 12:07 AM
Jim Ram's Avatar
hahaha awesome. Yeah I know the truck won't start with the drivers door open. I tried starting it while someone was gwaking at the interior in the drivers seat and it didn't work.
Old 09-14-2010, 12:31 AM
Rep:2657
your doors need to be locked, windows open or closed to start it
1 press of the button, unlocks the drivers door ONLY
2 times pressed, all other doors open, on mine if you continue to hold the button down on the 2nd push, the front windows drop
sometimes you have to push the button a 3rd time to get the front windows to go down
the front windows don't go back up until you insert the key & hit the windows up button
Old 09-14-2010, 10:48 AM
charlie3133's Avatar
charlie3133 charlie3133 is offline
Trim Level: SLT Plus
charlie3133 is on a distinguished road
You can change the unlock options in the EVIC though.
I have it set up so one button press unlocks all the doors
If you are what you eat then I am fast cheap and easy!
Old 09-14-2010, 04:21 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
I, too, have found that it's inconsistent. There are times that I'll get no response, so I wait a few seconds, and then it responds. Also, the range isn't nearly as good as the fob was on my last 300M. I can use mine maybe from 50 yards away but certainly not 100.
Also, I've noticed that the design of the fob is much more susceptible to keys being inadvertently pressed while in your pocket. Found both my windows half-way down the other day.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 09-14-2010, 05:31 PM
LBZ HEMI LBZ HEMI is offline
Vehicle: 2010 Ram
Trim Level: SLT Bighorn
LBZ HEMI is on a distinguished road
check the tsb and recall section i posted a RRT that dodge is doing in response to this issue take it to dealer and have it done hope this helps
