Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-14-2010, 12:38 PM
wcturner wcturner is offline
wcturner is on a distinguished road
Default 97 Dodge Ram
Truck will not start because it is raining out. Pluging in the block heater for a couple of hours seems to help. Once started it will start fine for the rest of the day.
Old 09-14-2010, 04:52 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Welcome to the forum. You might want to go to the UserCP and fill out a profile, since this is your first post. You can put in info on your truck, then, when people try to help, they will know what you are working on.
As to your problem, I would check wires, cap and rotor. Sounds like moisture is getting in causing the nonstart. Once it warms up, the moisture dissapates and everything works. If it's been a while since you replaced your wires, I would look for replacements that are 8mm, instead of the standard 7mm. If you replace cap and rotor, brass contacts are better than aluminum. Also a product called WireDrier that you can spray on your wires if they get wet. Displaces the moisture, but only for a little while.
Old 09-14-2010, 08:06 PM
Good advice there . You can also check and see if you have good fuel pressure and spark , that way you can narrow down your problem . Don't forget to stop by the newbie section and introduce yourself .
