Air leak from one tire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-14-2010, 02:07 PM
DirtRider's Avatar
DirtRider DirtRider is offline
Vehicle: 2010 Ram 1500 Crew Cab
Color: Diamond Black
DirtRider is on a distinguished road
Default Air leak from one tire
One of my tires is leaking air - slow about 4-5psi per week.
The truck is brand new. I checked for any punctures or nails and found nothing, the valve is not leaking and no other signs of damage.
Someone told me a while ago that the rim may have an imperfection in the cast with a tiny hole in it and that may leak air.
Is that possible?
Old 09-14-2010, 02:14 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I guess that could be possible.
If there aren't any nails then I try spraying some water around the valve stem. No leaks there then try spraying it around the bead.
After that I guess the dealership is the next option. I'm sure others will chime in if they can save you the trip.
Old 09-14-2010, 10:04 PM
moparornocar72's Avatar
Rep:630
More than likely on a new rim and tire it would be due to tap on weights causing a leak in the bead. Air your tires up to the MAX PSI then Take a spray bottle full of water and soap and spray the whole thing (bead,inside, outside) if it is leaking it will bubble up. You can also air it up that high and dunk it in water and it will bubble out and give you a better idea. If you have the means to take the tire off the rim sometimes it's easier to find a hole in smooth rubber than tread.
14.268 @ 95 MPH Full Trim
Old 09-17-2010, 12:10 AM
BJAMIN's Avatar
BJAMIN BJAMIN is offline
Rep:13
BJAMIN is on a distinguished road
Hey, not sure where you live but if it's in Canada go to Kal-tire, they'll check it out for free... they'll claim it'll cost 30 bucks but it won't. They just dunk it in a tank and look for air bubble. The other solution is a $10 kiddie pool. Unfortunately sometimes air leaks will only come out when the rubber is flexed in certain directions.... in that case... good luck.
Old 09-17-2010, 07:44 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I had a similar situation going on my truck. It was driving me crazy. I would get the TPM alarm about every 3rd or 4th day (often when it gave a psi reading of about 32-33psi).
I finally got tired of it, brought the truck in to the dealership, they couldn't find anything. So they added air and sent me on my way. Fast forward a week or so. The TPM alarm goes off again on the same tire.... brought it my local tire shop, had them check it out. Found a tiny piece of a nail hidden up underneath one of the tread lines. It took him about 10 minutes to pull it out (this was after he broke the tire down, couldn't get a grip on it at all with the tire "complete"). Tried to patch it twice, but for some reason the patch wouldn't take, air kept leaking... ended up putting in a plug.
They don't guarantee the plug anymore, apparently the patches work better. Go figure. Long story short... it didn't cost me a dime, and my tire is fixed.
Bring yours to a pro. They've got the equipment and knowledge to find the leak and fix it properly.
Exco
Bill
Old 09-17-2010, 08:29 AM
Resident Technician
Rep:1915
Yes it's possible. If you want a cheap way to find it yourself, take an old spray bottle and fill it iwht a mix of water and dish washing liquid. Inflate the tire to 35 psi and then spray the entire tire and wheel assembly. Don't forget to remove the valve cap and spray the valve as well. The leak should show upwithin a few minutes.
Old 12-21-2010, 02:26 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Question
Resurrecting this thread because I have a similar issue with snows I just installed on the Dodge Caravan my kids use. I just swapped the rubber on the existing rims (I know, not the best thing to have done). So now three of the four are loosing air slowly. Already took it back to the shop that did the swap and they are telling me the tires are crap, cracks along the bead. While they looked good to me and only had been used for two winters. So now what can I do, other than adding air once a week. I'm fishing for some ideas and don't really want to have them remounted. Would any of the spray in "fix a flat" stuff work ? Hoping one of you guys can offer a solution to try.
sales@revelperformance.com
Old 12-21-2010, 02:30 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
If you're not planning on taking it on long trips and only using the tires in winter, I'd use the fix-a-flat stuff and see if that works.
For next winter I'd suggest investing in some cheap rims and put new snows on them. Tires don't like being mounted and taken off often. The beads are designed to have stress on them, not sit with no air which results in the cracking you're talking about.
Brian:
Old 12-21-2010, 07:28 PM
RansRAM's Avatar
Addicted to the Z
Color: PXR Black
Rep:2477
Thanks RB. Yup, winter beater just for around town that I want safe enough for the kids to drive. I put air in this morning and read 38 psi. My daughter drove around today with it and tonight I checked and it read 37 psi. So it is a slow leak and that was the worse of the four. So I will try the fix-a-flat and see how it holds up. I'm planning on new tires and rims for it in the spring.
Old 12-22-2010, 03:47 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
I haven't used fix a flat cans before, but I know people who have and it worked for small slow leaks.
And Rootbeer is right, you need to keep winter tires on winter rims. Tires don't like to taken off and on rims repeatedly, especially cheaper tires will eventually form cracks along the bead.
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
