Old 09-14-2010, 08:34 PM
BenSamp BenSamp is offline
Vehicle: 2005 Dodge Ram1500 4x4
BenSamp is on a distinguished road
Default Driveshaft crud
Hello,
I got under my truck today just to look around and I saw fluid and gunk buildup around the place where the universal joint and the driveshaft meet caked up in that area. I sprayed some engine cleaner in that area and let is soak for a few minutes and pressure washed it off. So far I have not seen any leaks but I going to have it checked out, has anyone else had this problem in the past.
Old 09-15-2010, 01:38 PM
Rep:1625
Old 09-15-2010, 02:46 PM
Rep:2616
I have had that on almost every vehicle that i ever owned, no matter what brand
you did the correct thing, clean it up & check it periodically, if your vehicle has grease fittings, someone didn't wipe the excess grease off, if don't have the grease fittings, you may have sealed units that are beginning to lose the seal, if thats the culprit, then i would consider getting serviceable u-joints, from NAPA or a driveline shop, do NOT get the cheapies from Pep Boys, Kragen, Carquest, Oriellys, etc. they all have to much play or slop built into them. better brands are at least .020 closer tolerance
On the other hand, if the dirty build up is on the outside of the differentials pumpkin, it may be a loosening bolt or a differential seal starting to go bad, but, if the differential has not been taken apart, its not so likely to be that seal
Old 09-15-2010, 02:58 PM
Rep:1845
Most likely what you cleaned off is grease that has leaked from the joint.
Old 09-16-2010, 07:32 PM
Thanks guys,
I have been keeping a close eye on this, so far so good.
Old 09-16-2010, 07:54 PM
Does the u-joint have a grease fitting . If it does you may of just cleaned up excessive grease from the joint just as Randy has said .
Old 09-18-2010, 04:27 PM
I am going to get a closer look this weekend to see what is going on
