Gasoline preferences - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-15-2010, 05:48 PM
Rairwalk's Avatar
Rairwalk Rairwalk is offline
Vehicle: 2010 Ram 1500
Trim Level: Quad Cab
Color: Silver with Slate Gray interior
Rep:75
Rairwalk will become famous soon enough
Default Gasoline preferences
Hi,
Would like to know your preferences on gasoline. The manual says 87 or 89 prefered. Thanks for your input.
http://www.ramforumz.com/showthread....843#post310843
Rick
Old 09-15-2010, 06:53 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
87 and 89 no real differnece i used to run 93 when truck was tune. the 93 gas is really for like sport cars that use high compression engine need high octane gas so the engine does not knock which cause engine failure. if you hear it knock then you should change. Also a lower octane gas tends to build a carbon film on your cylinder heads. Usually, you won’t notice the difference in engine performance for the most part since most of your driving occurs in the city. The carbon film inside your cylinders will be confirmed if you open the engine to replace your head gasket when you rebuild your engine head or when you want to do an engine overhaul. Only then you will see what the different octane gas will do to your engine. So if you plan to keep checking your head gasket see what gas to use then you can do that. The ping that some people notice in their vehicles happens because the compression ratio changes due to the carbon build up which affects your timing chain performance.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-15-2010, 06:57 PM
Resident Technician
Rep:1915
You can get carbon buildup regardless of which octane fuel you choose. Fuel quality, driving habits, and maintainence have the greatest effect on carbon buildup.
Rairwalk's Avatar
Rep:75
Also brand. Anyone sure there brand of gasoline is by far superior than others?
Rick
Old 09-15-2010, 07:14 PM
Trim Level: st
Color: silver
Rep:68
i use whatever gas i can get
Old 09-15-2010, 07:29 PM
Allstate48 Allstate48 is offline
Vehicle: 2010 Dodge Ram-1976 D200
Trim Level: SLT- Orange&rust
Color: Cool Vanilla
Rep:53
Allstate48 will become famous soon enough
Our 89 octane is 10% ethanol. It's 10cents cheaper than regular at 87 octane. So that's what I run, from Casey's. Good luck Doug
Old 09-15-2010, 07:39 PM
Rairwalk's Avatar
Rep:75
I usually do too. Just curious.
Rick
Trim Level: st
Color: silver
Rep:68
run whatever you want unless you get a 93 tune i say run 87 my friend got 190k miles running 87 on it
Old 09-15-2010, 07:42 PM
Trim Level: st
Color: silver
Rep:68
no I understand knowledge is power
Old 09-15-2010, 07:58 PM
smeers59's Avatar
smeers59 smeers59 is offline
Vehicle: 2005 Ram Daytona
Color: Silver / Go Mango
Rep:103
smeers59 will become famous soon enoughsmeers59 will become famous soon enough
Rick
I have been running Exxon/Mobil 89 for the past 3 tanks, am now running Turkey Hill 89, and the last two will be Shell 89 and Shell V-Power 93. I am attempting to test out the "Top Tier" listed gasolines that are in my area. So far I like the Exxon/Mobil better than the Turkey Hill. The Turkey Hill feels sluggish when opening up, plus their pump is the only pump that has ever overflowed on me. With Exxon I was getting between 13.2 and 13.5, Turkey Hill 13.0 and 13.3 (all city driving + heavier foot than most). I can update again once I'm done with Shell.
Daytona 00293, 3.92, 4X4, Custom Two-Tone Silver / GoManGo Paint, Custom Vortex Hidden Exhaust, Sonnax Trans Line Booster, AirRam Scoop, Stubby Antenna, Spectre Breather Filter, 22" SRT-10 GunMetal Rims, Fully DeBadged, Injen PowerFlow Intake w/ PowerBox, DSP Performance 93 Tune
