Old 09-15-2010, 08:27 PM
hondaman01 hondaman01 is offline
hondaman01 is on a distinguished road
Default 2002 ram 1500 4.7l manual tranny clutch wont disengage
ok a few months back i was going to the lake towing my jet ski and on the way up the hill all of a sudden the clutch stopped working and i couldnt change gears, i lost almost all pressure on pedal as well
well i replaced the slave cylinder thinking that was the problem and i couldnt get it to bleed correctly so i bought a entire pre-bled system and just now put it on, and its doing the same thing as before so im thinking something is messed up inside the tranny
its weird it will disengage but only SLIGHTLY i press it to the floor and i can start it in gear and it will sit still but i let off of it even barely and it like jumps forward like im dumping the clutch, and it will not disengage it enough to change gears
the truck has only 34,000 miles and ideas on what it could be probably inside the tranny?
Old 09-17-2010, 08:09 AM
Rep:1625
Old 03-06-2011, 11:30 PM
ok finally got the tranny off and figured out the problem but i would like to know why this happened
the pressure plate had warped actually its the fingures that lift the pressure plate the throughout bearing is still good and the arm is still straight so i dont know
Old 03-08-2011, 12:01 AM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Warped pressure plate could be from excess heat. Chances are your clutch was slipping while going up the hill. It could also be from changes in traction. If you're going up a hill and randomly slipping going up the hill on some loose gravel then getting good traction it can really screw with the trans. Also make sure that your input shaft isn't bent. That happened to me on a drag car
Old 05-18-2011, 05:41 PM
to update, after i removed the old clutch and pressure plate from the engine to put the new one on, found that the pressure plate hadnt warped but the clutch fiber disc had seperated and doubled up on itself which is why it looked like it was warped and why it was locked up
pressure plate checked out ok, not warped not out of true or anything
was it just a flaw in the disc or just my bad driving? lol it was a little blue on the thin parts but im assuming thats from doing everything i could to get it home
thanks for all the help
