Loading pictures onto stereo - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-15-2010, 11:02 PM
UnLiMiTeD UnLiMiTeD is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:0
UnLiMiTeD is an unknown quantity at this point
Default Loading pictures onto stereo
Got the dvd navigation stereo in my 2010 ram 1500. I see theres a section where i can load up my own pictures, so i loaded up some pictures onto my usb flash storage but when i go to open it on the truck, no pictures show up.
Is there a certain picture format that i must use to get the truck to load them? They are all jpeg format.
Any help is appreciated, thanks
Old 09-15-2010, 11:22 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
While there is no real difference between jpg and jpeg, the name convention could be causing you a problem.
Brian:
Old 09-15-2010, 11:50 PM
Rep:0
Thought they were the same, just the normal format that pictures are saved under
Old 09-15-2010, 11:52 PM
Color: RootBeer
Rep:1287
Can you open the pics on the stick using your computer?
Brian:
Old 09-16-2010, 12:19 AM
Rep:0
yup, no problem. They dont even show up at when plugged into the truck though. It reads the drive fine, i just put 700 songs onto the truck from it
Old 09-16-2010, 12:51 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Did you put the pix in the root directory of the flash drive, or were they in a folder?
MyGig does not support folders.
brad
Interested in one of my mods?
Old 09-16-2010, 12:57 AM
Rep:0
mine does lol. Well atleast for my songs, picked the folders up for them just fine. I first had them in a folder, then took them out of the folder to see if that would make any difference and it did not.
Old 09-16-2010, 01:16 AM
brad12kx's Avatar
Rep:2581
I should clarify.....MyGig does not support folders for pictures
I also believe it has a limit on the number of pictures.....8
Having said that, it should be able to see the pix on your flash drive, but will only allow you to upload 8 of them.
Picture files must be jpg files. All others will be ignored. Although there are only minor differences between jpeg and jpg, I have not been able to upload any jpeg files that I renamed to jpg. the MyGig unit appears to be rather selective in what it will recognize. I don't believe there is a file size limitation, but it wouldn't surprise me if there was. I resize all my pix to 1024x768 prior to uploading, and have had great success.
brad
Old 09-16-2010, 01:19 AM
Rep:0
Well under properties it says:
File type: JPEG bitmap image (.jpg)
All my pictures are that and thats the only jpg option i have when it comes to saving images for jpg. It seems to me they are the same because all programs i open the images under and view them it associates jpeg and .jpg as the same thing
Old 09-16-2010, 01:26 AM
brad12kx's Avatar
Rep:2581
That should be fine, as the file is still a JPEG file. As long as it's saved with the jpg extension, it appears to work. I've done this many graphics programs, and all have worked well. the problem only appears if I save as a .jpeg then rename the file to .jpg. for some reason it doesn't work. Must be one of those 'random features' that were originally developed by Microsoft Corporation.
brad
