Tape on air deflectors... just wondering - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-17-2010, 04:00 PM
BigDaddyHock's Avatar
BigDaddyHock BigDaddyHock is offline
Vehicle: 2014 Dodge Ram Sport Crew Cab
Rep:40
BigDaddyHock is on a distinguished road
Default Tape on air deflectors... just wondering
if anyone has tried removing those after a year or two. Any paint damage? Reason I'm asking, just got my new set from JC Whitney, still in package and was thinking of returning for in channel.
Old 09-17-2010, 05:47 PM
I've removed a lot of stick on items after a lot more than a year or two.
Get some 3M Adhesive Remover. It comes in a spray can and you can find it at NAPA stores for sure. Some of the other major auto parts chains may have it as well.
Just spray some at the top of the adhesive section, let set 5 - 10 minutes, then peel off. Use a soft rag with more remover on it to remove any lingering adhesive and yer good.
Old 09-18-2010, 07:38 AM
Rep:40
thanks! I ended up installing the vents but still not sure if I like them. Figured I will see how these act on the interstate and hold up. If it's annoying, they will be removed. Picking up a can of that to keep on hand.
Old 09-18-2010, 08:27 AM
I have had the stick on ones on my '01 since new . Stick doing great .
Old 09-18-2010, 04:38 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Check out this post, it will save you a ton of elbow grease if you decide to take them or any adhesive type thing off.
http://www.ramforumz.com/showthread....ghlight=eraser
Brian:
Old 09-18-2010, 05:12 PM
Resident Technician
Rep:1915
I've had mine on for 3 years with no problems at all.
