Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Place your Ad Here!
Old 09-17-2010, 04:47 PM
cbearss22 cbearss22 is offline
cbearss22 is on a distinguished road
Default Problem with 99 2500 v10
Need some help. I have a 99 v10 ram and it has been to 7 mechanics and non can figure it out. Once in a while (maybe once a week) when accelerating or just cruising along it will start to studder and act like it wants to stall out but will never actually stall. When I floor the gas it fixes it and its fine for a week or so. Occasionally a check engine light comes on saying it bank one sensor 2 O2 sensor, but when it gets tested it checks out fine. Any ideas? Also My truck has a his sound almost like a turbo, was wondering if that is normal? Thanks for any help
Old 09-17-2010, 10:33 PM
slikkwilly002 slikkwilly002 is offline
Vehicle: 2011 Dodge ram
Trim Level: Sport 4x4
Color: Blue
slikkwilly002 is on a distinguished road
I know the problem... its called BFM (big fuc*in motor) lmao
Nah, really though maybe just a tune-up, or a good throttle body cleaning
Old 09-17-2010, 10:42 PM
I'm not sure what location that sensor is . But try banging on the bottom side of the catalytic convertor when it's cold and see if it rattles . If it does you may have a bad cat . The hissing your talking about may be coming from the guts in the cat clogging up the outlet and also causing the code to set .
Old 09-17-2010, 10:50 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
How old is the fuel filter? A semi clogged one can cause hesitation. Also check to see if there is more than one. I've seen where there is one on the motor and one along fuel line under the truck.
Brian:
Old 09-18-2010, 12:12 PM
Thanks for the tips, cats should be good, just changed them out about 6k miles ago but ill check
Old 02-05-2011, 10:04 PM
thebuthcher thebuthcher is offline
Vehicle: 1998 ram 2500 v10
thebuthcher is on a distinguished road
i have he same thing happening to me i just bought an 98 2500 v10 when i accelerate it falls on its face i need help with this as well please
Old 03-16-2011, 10:49 PM
dirty dodge dirty dodge is offline
dirty dodge is on a distinguished road
i haad this exact same problem with mine. i put a new o2 sensor on it and it totally fixed it. hope this helps.
Old 09-13-2011, 10:47 PM
sbaldee66 sbaldee66 is offline
Vehicle: 2000 Dodge Ram 2500
sbaldee66 is on a distinguished road
I don't know if you are still having this problem, but my truck did it and the local shop told me it had bad cats. We cut out the cats, the problem didn't go away. Took it to my local dealer, it took them a while but they figured out it had a bad ground for the O2 sensors and the A/C. They installed new end on ground wire and my truck runs better than ever! Have your shop check the ground that runs your o2 sensors and your A/C.
Old 09-14-2011, 12:15 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
hope you can get it figured out bud and have that big ol v10 purrin like she is suppose to
Old 07-21-2013, 12:16 AM
Andy72 Andy72 is offline
Vehicle: Dodge 2500 99 v10
Andy72 is on a distinguished road
I have the same sort of thing happening with my v10 push the gas and all I get is sputters then it cleans up and I can drive it for the rest the day like a striped ape
I'm puzzled by it!
This is ware I'm at so far, I live in California and my cat went bad so I replaced it, my v10 came to me with a single cat, what I found out is that a single catalytic converter actually is for the v8 model, so I was hoping that hey! This truck has had 120k miles no problem no trouble lights why change it!
Within 50 miles of changing the cat I have a check engine light bank one o2 sensor' comes on,
I have also come a crosse a problem with this truck if you have dirty battery termanals it will run really crummy
Doesn't have to make sense to happen!
Any one have any advise
