Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-18-2010, 02:48 PM
scottish rumble's Avatar
scottish rumble scottish rumble is offline
Vehicle: 2004 dodge ram 1500 4x4
Trim Level: lamarie
Rep:54
scottish rumble will become famous soon enough
Send a message via MSN to scottish rumble
Lightbulb fitting a leveling kit
im looking to fit a leveling kit to my ram above, its a 4.7 magnum 2wd 2002 model.
i have been looking at the leveling kit from summit racing to lift 2" i am wondering is it straight forward to do or are there any special tools and extra things i need to buy like shocks and anything in unaware of.
im in the uk so im not around rams alot and recently purchased this ram which i will get this wed so this is the first planned mod.
any help will be much appriciated and if there are any vendors on this site that can supply and ship to the uk bill be helpfull
thanks
billy
When your bigger than the rest, what do you say, move it or loose it
billy
Old 09-19-2010, 09:31 PM
Rep:1625
Old 09-25-2010, 05:01 PM
Trim Level: lamarie
Rep:54
big thankyou to randy (ramtech) for the info needed aswell as ram4me
will be fitting the leveling kit real soon
billy
Old 09-25-2010, 10:59 PM
Consider doing a How to Install Pictorial . That would be great . I could see alot of rep points heading your way .
Old 09-26-2010, 10:11 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Agreed. I would supe rinterested in a how to on this.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 10-11-2010, 01:03 AM
matt99 matt99 is offline
Rep:20
matt99 is on a distinguished road
how to on a level? easy as pie....you will need new shocks
take tire off, brakes, hub, seperate sway bar, spindle on top or bottom, rent a spring compressor and then allow lower control arm to fall, take spring out and put spacer on top (with or without stock isolator) then reinstall back the way you took it apart
dont forget to put the end of spring in the indention, and you will need an alignment afterwards
[IMG]http://i294.photobucket.com/albums/mm110/swollguy99/1282248743-1.jpg[/IMG]
Murdered
Old 10-25-2010, 04:08 AM
Ben Legere's Avatar
Ben Legere Ben Legere is offline
Vehicle: 2007 Dodge Ram Quad Cab
Ben Legere is on a distinguished road
You can use your old shocks.
Remove your shock then use an internal spring compressor to compress your spring before you jack your truck then jack it up by it's frame and remove the tire. Once you have your truck in the air with the tire off take the nut off of your top ball joint then tap your upper control arm out of the way and slip the spacer over the top of the spring. Reconnect your upper ball joint and throw your tire on. Lower your truck to the ground then take the spring compressor off and install your shock.
It takes about 30min to level your truck.
http://www.myspace.com/534215153/photos/8022789
