Old 09-18-2010, 06:27 PM
slavikslayer slavikslayer is offline
slavikslayer is on a distinguished road
Default bang in reverse
the problem being that when it was in neutral, and id throw it in reverse you could hear a loud bang. you could feel it through the truck cab. does anyone know what this could be , had my rear end rebuild, and did not help. Any sugestions ?
thanks,
2000 Ram 2500 , 5.9 Magnum, 46RE transmission
Old 09-18-2010, 06:31 PM
Resident Technician
Rep:1915
I would think engine/trans mounts or perhaps some excessive slop in the transfer case chain. My last guess would be in the trans itself.
Old 09-18-2010, 06:44 PM
i think it is worse if the truck is parked up the hill. and feels like there is pressure on the wheels, then you can hear it a lot only when going from park to reverse, no problems changing gear while driving, same thing in 2x or 4x4 ,
Old 09-18-2010, 06:46 PM
Resident Technician
Rep:1915
If you can get someone to help you, have them shift between reverse and drive while you try to narrow down where the noise is coming from.
Old 09-18-2010, 06:47 PM
Default RamTech thanks for your help
any info would be lots of help
Old 09-18-2010, 06:53 PM
I'll do that,
Old 09-18-2010, 07:54 PM
When you park on a hill are you using your park brake ? If not your putting alot of pressure on the park paw in the trans . It takes alot of force to disengage the paw at that point and when it does that will make alot of noise .
