Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 09-18-2010, 08:13 PM
Holymolymon Holymolymon is offline
Vehicle: 2010 Dodge Ram Quad Cab
Holymolymon is on a distinguished road
Default Low Idle Speed
I have 2010 Ram with the 5.7 Hemi and less than a thousand miles. The idle is normally at 6000 RPM's. I now notice that the RPM's are sometimes a little under 5000. I'm not sure when this started or if it has done this since I bought it last month. But now that I am watching it, today I noticed that when I stopped the idle dropped to about 4000 RPM's then immediately went back to 6000. Also the engine seems to have a lot more engine noise than I would have thought a new truck would have. Not exhaust noise but a lot of ticking which I assume is the fuel injectors. Much louder in the garage of course. I appreciate any thoughts or suggestions. Thanks.
Old 09-18-2010, 08:16 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I think the rpms you mean are 600, 500, and 400.
Those would be normal. Its all computer controlled.
The ticking noise at idle is the Hemi tick, also normal.
Brian:
Old 09-18-2010, 08:18 PM
Rep:1890
You have the Hemi tick. Perfectly normal. As for the idle speed, You mean 400-600 rpm, right? IF the truck starts dying or giving any problems, have the dealer check it out.
Old 09-18-2010, 08:22 PM
Yeah I did mean between 400 and 600, but still don't understand why it would very.
Old 09-18-2010, 08:23 PM
Lets get this right, I mean Vary.
Old 09-18-2010, 08:24 PM
Color: RootBeer
Rep:1287
The computer is set to give optimum mpg and sets the idle based on the demand put on the motor.
Turn everything off and look at the rpm, then start adding things like max a/c and see what happens. Then put it in gear for another test.
Brian:
Old 09-18-2010, 08:27 PM
I'll give that a try and thanks for the fast reply.
Old 09-20-2010, 09:50 AM
mge1's Avatar
mge1 mge1 is offline
Vehicle: 2014 Ram 1500 Crew Cab
mge1 is on a distinguished road
Send a message via AIM to mge1 Send a message via Yahoo to mge1 Send a message via Skype™ to mge1
Quick question. When at idle (500) do you guys feel a little bit of shaking also? I am assuming its normal.
