Old 09-19-2010, 06:55 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Default glasspack clarification
Hey everyone, I was reading a thread about what muffler to use, and Is a glasspack going to pass emissions. Someone stated they had just installed a cherrybomb on their ride and say they are only good for disturbing the neighborhood and you get no hp gains. Is this true? I've got a shorty cherry bomb on mine and I was under the assumption that because it flows straight thru no baffles/chambers=more performance. Some more info would be great.
Old 09-19-2010, 07:07 PM
If the Cherry Bomb significantly reduces backpressure, it's good for higher RPM flow but it will rob you of low end torque. And that's not a good thing. You do need some low end torque off the line to move the truck.
As far as emissions go, that's pretty much dictated by your local laws and emissions requirements. However, in my experience, you can have what you like as long as your emissions equipment is in place and functioning correctly, i.e., no engine codes.
Old 09-19-2010, 07:10 PM
Most glasspacks are illegal because of how loud they are . They don't effect emissions . They aren't real good flowing air . If they were don't you think race cars would be running them .
Old 09-19-2010, 08:45 PM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
Here's some good info on mufflers:
(copied from another site)
I have listed here a muffler shootout test done by CAR CRAFT, they show the best bang for the buck, and show the db's
The Mufflers
MAKE MODEL Part No. COST
SUMMIT Turbo 630125 $14.75
THRUSH Magnum Glasspack 24214 $16.50
THRUSH Boss Turbo 17718 $23.95
HOOKER Competition 21006 $25.95
DYNOMAX Super Turbo 17733 $28.50
DYNOMAX Race Magnum 24215 $31.95
HOOKER Super Competition 21106 $35.95
SUMMIT Fully Welded 630325 $38.69
FLOWTECH Afterburner 50322 $39.95
MUFFLER FLOW TEST
MUFFLER Flow at 28-in H20
DynoMax Race Magnum 528.64 cfm
Thrush Magnum Glasspack 507.40 cfm
Summit Fully Welded 343.38 cfm
Flowtech Afterburner 342.20 cfm
DynoMax Super Turbo 333.94 cfm
Hooker Competition 232.46 cfm
Hooker Super Competition 320.96 cfm
Summit Turbo 331.16 cfm
Thrush Boss Turbo 297.36 cfm
MUFFLER Idle dB WOT dB
DynoMax Super Turbo 89 123
DynoMax Race Magnum 94 133
Flowtech Afterburner 92 124
Hooker Competion 92 122
Hooker Super Competion 90 125
Summit Turbo 89 124
Summit Fully Welded 92 125
Thrush Boss Turbo 90 123
Thrush Magnum Glasspack 92 128
DYNO TEST
All mufflers were dyno-tested on a 355-cube SBC with 10.0:1 compression, Air Flow Research 190 aluminum heads, a CompCams 292 hyd. a Victor Jr. intake, a Holley 750-cfm double-pumper, and 1 5/8 Headman headers.
MUFFLER HP TORQUE 2,500-6,000rpmAverage
Hooker Competition 397.4 381.1 286.8hp/351.9 lb-ft
Thrush Boss Turbo 407.1 384.9 292.1 hp/357.5 lb-ft
DynoMax Race Magnum 409.5 394.3 298.8 hp/366.9 lb-ft
Flowtech Afterburner 409.7 391.2 294.8 hp/361.7 lb-ft
Thrush Glasspack 409.5 389.8 297.7 hp/365.3 lb-ft
Summit Turbo 411.5 386.3 291.5 hp/357.4 lb-ft
DynoMax Super Turbo 412.7 387.2 292.6 hp/358.6 lb-ft
Hooker Super Comp 413.8 387.2 292.8 hp/359.0 lb-ft
Summit Fully Welded 415.4 390.7 295.6 hp/362.4 lb-ft
i have another test here on my computer but i don't know how to upload it onto this site because it is in a adobe pdf file.
more numbers for ya'll who like numbers.
All tests via an independent lab
All tests @ 15 wc
2 Straight Pipe 283 CFM
2 Straight Pipe 365 CFM
2 Straight Pipe 521 CFM
2 Typical Bent tailpipe 268 CFM
2 Typical Bent Tailpipe 417 CFM
2 Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 Cherry Bomb 239 CFM
2 Cherry Bomb 294 CFM
2 Inlet/Outlet Dynomax Super Turbo 278 CFM
2 Inlet/Outlet Ultraflow Bullet 512 CFM
2 Inlet/Outlet Gibson Superflow 267 CFM
2 Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 Inlet/Outlet Thrush CVX 260 CFM
2 Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 Inlet/Outlet Hooker Aero Chamber 324 CFM
2 Inlet/Outlet Hooker Max Flow 521 CFM
2 Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 Inlet/Outlet 138-152 CFM
Standard OEM 2 Inlet/Outlet 161-197 CFM
This should give some idea about glasspacks to y'all. I have ran them in the past, but I wouldn't run them now.
The glasspack infor is in Blue, and my fav muffler is in red
Mufflers do not have anything to do with emissions. All of the state's I have researched laws on state that a muffler must be in place and in good working order, and be less than the allowable noise (Db) levels. The noise levels is what you should be concerned about as far as legality, as any aftermarket muffler is technically legal as far as emissions (including "race" mufflers) but may not meet your states noise restriction laws.
Old 09-19-2010, 08:47 PM
^^Some good info there^^
Old 09-19-2010, 09:04 PM
kmdracer's Avatar
Rep:43
Really good reading here:
http://www.superchevy.com/technical/...xh/index1.html
Old 09-20-2010, 07:45 PM
toddrod's Avatar
Color: Yellow
Rep:55
Hey thanks for all the info, I'll probably pull that cherrybomb and go shopping for something else really soon.
