Whats wrong with my 1997? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-22-2010, 06:57 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
when you have the intake off, (to change up the cap and rotor, and spark wires) put a new plenum gasket in. fel pro has a set of premium gaskets well worth the money.
use tender loving care when you break loose the manifold bolts...especially the front 2 and the rear 2. Chances are they are about 3/4 corroded through. Then put antiseize on them when installing..
Old 09-22-2010, 08:33 PM
rph1's Avatar
rph1 rph1 is offline
Vehicle: 1997 Dodge Ram
Trim Level: Sport w/ SLT decor
Color: Poppy Red
rph1 is on a distinguished road
I was told to go through hughes Engines and get the aluminum plate that replaces the factory steel plate for the plenum.
Ryan Herring --> 97' 2500, 360, 3.55
Old 09-22-2010, 09:45 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Some folks here have had some improvement in power and mileage with an aftermarket coil but I would install some new, inexpensive, stock plugs first and see if that helps. If it does, then go for the kit.
Old 09-22-2010, 09:54 PM
rph1's Avatar
Color: Poppy Red
good point....
Old 09-25-2010, 08:56 PM
rph1's Avatar
Color: Poppy Red
Today I adjusted my throttle position sensor, checked my vacuum line, and changed the muffler. What a difference. The vacuum line on the front was dry-rotted so i changed that. My plans were a magnaflow but i settled for a 28" thrush glasspack.
Check your vacuum lines from the throttle body . I found some on mine that were in poor shape and may of been effecting my mileage also . The one that I think were really effecting it was the one from the passenger side/front of the throttle body to the firewall and around to the r/f fender . Thank you Toms Blue Ram 1500
Old 09-25-2010, 09:00 PM
rph1's Avatar
Color: Poppy Red
^Couldn't figure out how to quote ya there Toms Blue Ram 1500^
Old 09-25-2010, 10:37 PM
I read it . Hopefully that will help ya out .
