Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - SIGS - Special Interest Groups > Public Safety
Public Safety Special Interest Group for Police/Law Enforcement, Fire, and EMS Personnel! - Click the badge to the right to request membership>>
Old 09-20-2010, 03:08 AM
NSEP Fleet Mechanic NSEP Fleet Mechanic is offline
Vehicle: 2000 Ram Crew Cab 4x4
Trim Level: Lariat
Color: Tan
NSEP Fleet Mechanic is on a distinguished road
Default question regarding emergency equipment
How well do the systems on a stock ram hold up to emergency equipment? im considering adding a 4 head strobe pack (headlights and taillights) as well as a federal signal pa300 siren system, and a code 3 MX7000 lightbar (4 strobes, 3 rotators, intersections, alleys, takedowns and a traffic advisor) just wondering if there are any areas i should be concerned with
thanks
Old 09-28-2010, 04:35 PM
Rep:1882
Any idea what kind of amperage you'll be drawing?
Old 09-28-2010, 07:18 PM
Rep:2640
i run my 2009 Ram almost daily for several hours at a time & i don't see the gauge moving
my headlights are on ALL of the time
i run 2 TARGET rotating lights, 12 v , Model 443112 Series B .. SAE-W3-94
CB radio is a Ranger RCI-6900F 150 , tweaked to run full power
http://www.bellscb.com/products/tenm...F150_front.jpg
also available from http://www.nationsautoelectric.com/bosch.html
BOSCH High Amp alternator
03' UP Dodge Ram Trucks 5.7L Hemi and 5.9L Diesel
Voltage: 12 Volts
Amps: 230 Amps
Regulator Position: 10:00
Polarity: Negative
Output Stud Dimensions: M8-1.25
New or Remanufactured: New
Notes: External Regulated Alternator
Application: 2003-ON Dodge Ram Truck & SUV with 5.7 L Hemi
GAS
Also Will Fit Dodge Diesel 5.9L 03'-On Applications With 8S
Pulley Installed.
Select Gas or Diesel Engine
230 Amp Alternator Price- 499.95..................
Call for availability 1-888-334-2632
Now We Have a 290XP Series Alternator!
Call for availability 1-888-334-2632 begin_of_the_skype_highlighting 1-888-334-2632 end_of_the_skype_highlighting
We also have alternators for the 3.7L &4.7L Dodge &
Chrysler Truck & SUV
Old 10-01-2010, 12:11 AM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
90% of your draw will be in your mechanical lights.. ie rotators etc...flasher kits with REGULAR bulbs will draw the second most. strobes and leds will draw way less.. if you can get away from extra rotators, do so if you are running close to your max amp draw / alternator output.
It will help out a lot to change ur regular lamp bulbs to LED's if you can.
Chili
Old 10-01-2010, 12:23 AM
Rep:2640
my equipment is so old, that most of it was built in 1994, talk about major amp draw
i'll be glad when ALL the USA allows LEDs & Strobes, i'm running out of lithium grease trying to keep the old equipment running
Old 10-08-2010, 03:50 PM
CRASHCOSBO CRASHCOSBO is offline
Vehicle: 2010 Ram 1500 QC 4x4
CRASHCOSBO is on a distinguished road
I was going to ask why so many on here seem to lean more towards strobes and rotating lights...I guess it is some sort of legal thing? we have completly phased out strobes with our equipment here and only have a few of the old code 3 roof grinders left in service. Our stuff now is almost entirly LED based. Are the laws in the process of being changed in some states?
Remember...Gravity is not just a good idea...It's the law!!!
Old 10-19-2010, 04:03 AM
96RamC's Avatar
96RamC 96RamC is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: SLT Laramie
Color: Turqouise / Flat Black
96RamC is on a distinguished road
Before I took off my equipment to start modifiying my truck (Old whelen light bar, federal signal siren/pa/speaker setup, and arrowstick) and gave it to my buddie for his ram it held up pretty good.. I upgraded to a 140amp alternator for the just in case factor.. but i never had a issue... I do however suggest the LED's just due to the increased realibility of them, and the low power draw.
"If you fail the first time, don't quit. Keep trying until you can do it perfectly"
