Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-20-2010, 12:17 PM
NWTJetboater's Avatar
NWTJetboater NWTJetboater is offline
Vehicle: 2009 Dodge Ram
Trim Level: Fully Loaded
NWTJetboater is on a distinguished road
Default Air Conditioning/Heating Problem
Hello All
I have a new to me 2009 DR Laramie.
The problem is that every time I start the truck with the key the AC comes on.
If I use the remote start it will default to my settings and then when i put the key in the ignition the ac again comes on even if the temp is set to high.
Is this a software issue ? or is the controller in need of replacement?
"If you ain't hitting bottom, you ain't jetboatin !"
Old 09-20-2010, 12:39 PM
Rep:1890
Do you have it set to defrost or will it do it in all positions?
Old 09-20-2010, 01:07 PM
It will do it in all positions. I just tried again. So even if I start the truck shut AC off while in defrost mode and then turn left controller knob to Auto the AC again comes on. Very strange. I am in the sub-arctic and will not need ac for another 9 months lol.
Old 09-20-2010, 07:44 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Mine does it too. Kinda bummed about it because I intalled the remote start for the vary reason of starting the AC or heat early.
Old 09-20-2010, 07:51 PM
Rep:1890
Have either of you checked the manual to see if you can change it?
Old 09-20-2010, 08:51 PM
CHVYKLR's Avatar
Rep:252
I should've checked there first. All I could find is that the heated steering wheel, heated or vented seat option work with remote start.
page - 260
Old 10-04-2010, 01:18 PM
Ok this is getting frustrating. I do not want AC coming on at all on its own. I just read that with the AC compressor on I will use 25-30% more gas. Every time I adjust the settings the AC comes on, start the truck AC comes on this is crazy..any one have any ideas to correct ?
Old 10-05-2010, 06:41 AM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
My old truck (07 Silverado) has programmable driver / passenger heating and cooling, if it is set to recirculation it automatically turns on the A/C. Might be the same for Dodge. Just remembered turning on the a/c will help defog or defrost the windows.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors.
Future Mods: What ever I can sneak by my wife.
Old 10-05-2010, 09:54 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
The A/C can not use 25-30% more gas!! If it does, you have a bigger problem.
Have you been to the dealer for warranty work? There was a computer flash for mine.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 10-07-2010, 01:30 PM
glamontagne's Avatar
glamontagne glamontagne is offline
Vehicle: 2009 Dodge Ram Crew
Rep:55
glamontagne will become famous soon enough
I've never heard of the A/C using that much more gas.
Gary--2009 Black Ram Crew 5.7 Truck Champ Stainless tube steps,Tekstyle Tonneau Cover, LED Interior, LED License Plate Lights, LED Reverse Lights, LED Cargos, 5900k Headlights and Fogs.
