Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-20-2010, 08:45 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Default Leaking Evaporator Core?
Hey guys,
I've had a leak in my a/c for a while now, bad enough that I won't put in any more cans of refridge. I took it to Car-X and they couldn't find it (although they did replace one of the steel lines that didn't need replacement ). When I called they said it's possible that it's the evap core and that I should be able to see the dye but I'm not sure where to look. anyone know where I might see the dye?
Many thanks,
-Mac
Old 09-20-2010, 08:48 PM
Resident Technician
Rep:1909
You won't always see dye in from the condensation drain if the evap core is bad. You need to look for another shop that knows what they're doing.
Old 09-20-2010, 10:05 PM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
I'm thinking it's gotta' be the evap core. I've put loads of dye refridgerant in it and can't see dye anywhere. From what I understand it's near imposible to get to the core. Anyone ever use this sealer?
http://acstopleak.com/index.html
Might be worth a try.
Old 09-20-2010, 11:37 PM
I wouldn't recommend it . It's just better to man up , bit the bullet and fix it correctly . While your there do your heater core also . This generation Ram was notorious for leaking heater cores and evaporators . I've replaced the heater core in mine already and now I believe I have a leaking evaporator . When I do the evaporator , I will replace the core again . If your mecnanically challenged I would recommend finding someone who has done dash work and not afraid to tackle this . It's alot of work and you want to make sure whoever does it does a good job for ya . Another thing that will be a concern will be the dash itself . Again with this generation Ram , The dashes are prone to crack and fall apart . So be prepared .
Old 09-21-2010, 09:11 AM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
Thanks Tom, that was one of my concerns. My dash has a couple of very fine cracks that I'd rather not make very large cracks. Good advice on the heater core.
