Old 09-20-2010, 10:13 PM
cole3986 cole3986 is offline
Vehicle: 2010 Crew Cab 4x4
Trim Level: SLT Big Horn
Color: silver
cole3986 is on a distinguished road
Default What is Wrong with This Picture
6 Ton deckover trailer hitch does not like the ram tailgate. I did not anticipate this problem.
Old 09-20-2010, 10:30 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
oh that sucks hope you find a solution other than not being able to put your tailgate down
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 09-20-2010, 11:08 PM
brolland's Avatar
brolland brolland is offline
Vehicle: 2014 Dodge Ram 1500 Crew Cab
Color: Granite
Rep:78
brolland will become famous soon enough
Why not use a "Dropdown" towbar. I can't tell from the pics but it looks like your using a receiver that comes straight outta the hitch. Can you use a 2" or 4" drop and still tow?? From the first pic it even looks kinda like the receiver is lifted a bit!
Old 09-20-2010, 11:17 PM
I agree , just a little obstacle . By the pic it looks like your not gonna need much , use a small drop hitch . You have a tall trailer there .
Old 09-20-2010, 11:59 PM
Color: silver
If I use a drop down hitch the trailer will not be level but will tilt forward -towards the bed. A trailer that is not flat adds tongue weight that is proporitional to the amount of tilt. Even reducing the trailer tire size will not fix the problem (it woudl help). I may have to settle on a lower hitch and place the load further back on the trailer axles to keep the tongue weight down. Some of the load my end up hanging over the dove-tail
I did not think of this when I bought the track because the hitch height is almost identical to the truck the dodge replaced (f-350 diesel).
Good suggestions-just an oddball combination- who towes with a 6 ton trailer with a 1/2 ton truck (obviously the trailer will not be loaded to 12,000 lbs). Just trying to do everything with one truck
Old 09-21-2010, 12:24 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
No intention to argue with you, but looking at the pics you posted, the trailer seems to be nose up. Maybe different pics would give us what we need to help you.
As for the load being on the hitch, maybe getting a load equalizing hitch will take care of the problem.
Brian:
Old 09-21-2010, 12:38 AM
RainmanX RainmanX is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:19
RainmanX is on a distinguished road
Was that trailer originally designed for a pintle hook setup? If so, it was designed to be hitched to a very large truck, such as a dump truck.
You should take that to a trailer dealer and see what they can do. You can do some lowering with different hitch assemblies or with an extension to lengthen it.
I actually have this system http://www.inventivehitches.com/9110.html
Old 09-21-2010, 12:44 AM
Blackzilla's Avatar
Vehicle: 2009 Reg Cab S/B 4X4
Trim Level: Sport/SLT
Color: Black Pearl
Rep:199
LMAO i look at the photo the hitch is reverse.....flip it over then put the ball on......looks like a 2'' drop that you have this mite solve the problem.
Old 09-21-2010, 01:59 AM
inkdemon's Avatar
inkdemon inkdemon is offline
Vehicle: 2010 Dodge 1500
Color: Cool Vanilla
Rep:37
inkdemon is on a distinguished road
Send a message via AIM to inkdemon Send a message via Yahoo to inkdemon
Slight drop will level your trailer by the looks of it. She's definately looking ass heavy
Old 09-21-2010, 02:23 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Yeah it definitely needs corrected at the receiver. You won't want to start putting the weight to the rear of the trailer to even it out. Especially on rear-light 1/2 ton's. You get into dangerous trailer sway doing that in my experience (former RV Technician).
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
