Old 09-21-2010, 07:30 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Originally Posted by cole3986 View Post
6 Ton deckover trailer hitch does not like the ram tailgate. I did not anticipate this problem.
Agree with the others. The rug is in the way but it kind of looks like the ball is mounted on the wrong side of the ball mount.
Old 09-21-2010, 07:50 AM
1RamRunner 1RamRunner is offline
Rep:19
1RamRunner is on a distinguished road
You could always drop the hitch and raise the truck
Old 09-21-2010, 08:29 AM
SvB4EvA's Avatar
SvB4EvA SvB4EvA is offline
Vehicle: 2010 RAM 1500 4x4
Color: Inferno Red
Rep:25
SvB4EvA is on a distinguished road
Originally Posted by RainmanX View Post
I actually have this system http://www.inventivehitches.com/9110.html
I like that!
-Steve
Old 09-21-2010, 09:46 AM
cole3986 cole3986 is offline
Vehicle: 2010 Crew Cab 4x4
Trim Level: SLT Big Horn
Color: silver
cole3986 is on a distinguished road
To All- thanks for the input. The trailer has a pintel receiver (7 ton eye) and can carry 9,500 lbs (the trailer weighs 2,500 lbs or so). The reciever is on the lowest setting on the trailer and the pintel that is partially covered with the rug is a combination pintel hitch with a lower ball so that it could be used as either a ball or pintel depending on what you are towing.
The pictures are not good- should have spent more time and the ground is not level. The trailer appears to be too high. As all have suggested, I need to lower the reciever height or raise the truck. It worked will on the Ford because the hitch was a little lower in relationship with the truck body and the tail gate was thinner. I had not thougtht about raising the truck- this may be a good excuse. The great thing about a deck over trailer is that trailer is 8.3 feet wide and you can put anything on it- just a really high trailer and not something that is normally done withe any 1/2 ton pickup (the trailer will not be loaded with more than 6,000 lbs- the trailer is normally used to transport Massey Ferguson 1035 tractor w/loader and 5' rotary cutter- weighs about 4K).
Thanks again
Old 10-01-2010, 06:13 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
Default trailer
The trailer should be within 3-4 inches below or above the ball height. If it is too high it will lift the truck and if too low it will dive under this is when a hard stop. Been towing for 34 years. All of the towing tech's will tell you this
Old 10-01-2010, 07:27 PM
Rep:2890
if you don't have the tailgate with the $20 helper spring that attaches to the truck bed & tailgate. (it makes the tailgate 80% lighter when opening & closing)
http://www.nationaltruckaccessories....p/easylift.htm
you can easily take off your tailgate & use a 5th wheel tailgate while towing
http://www.etrailer.com/Truck-Bed-Ac...D-02-2000.html
