Old 09-21-2010, 08:13 PM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
Default A/C Condensor Fan or Low on Freon?
Okay, I notice my a/c condensor fan won't turn at times but I also noticed that the compressor cycles more than usual.
Question is, Is the fan not turning on due to low freon or is the compressor cycling more due to the fan not working properly?
New to this issue. Though I have seen posts about the fan. I thought I would try this question.
Is there something else that could cause this? A relay?
It does come on at higher speeds but as you slow down or stop at a red light it stops cooling.
TIA
dksram
Old 09-21-2010, 08:20 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'd say take it to a shop and have your freon level checked then start from there. If you know what you're doing you can buy a set of gauges and do it yourself.
Brian:
Old 09-21-2010, 08:23 PM
I would have guages hooked up and verify your freon pressures . All your problems may stem from that .
Old 09-27-2010, 03:53 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
when the a/c is on, the fan should be on at all times. if the fan isn't running it will cycle quickly, hiss from the passenger side and not cool.
Old 09-27-2010, 07:18 AM
Rep:1885
This is going to depend on ambient temps and system pressures. Rapid cycling is an indicator of low refrigerant.
Old 09-28-2010, 03:42 AM
Trim Level: sxt
Rep:197
but if the motor is not running, won't that cause the rapid cycling? sounds as if the motor should be fixed no matter what
Old 09-28-2010, 04:11 AM
dksram's Avatar
Rep:27
Well after pricing the shops to check freon levels I decided to try the fan motor. 27.00. If it works I'm okay, if not, I can take it back.
Shops want to charge minimum hourly labor to check freon. 85.00 an hour.
