Old 09-21-2010, 10:16 PM
WesGPS's Avatar
WesGPS WesGPS is offline
Vehicle: 2005 Dodge Ram HD 4x4 S. Box
Rep:68
WesGPS will become famous soon enough
Exclamation Help needed for axle rating question please.
I have an AAM 14 bolt rear end in my truck. The axle tubes measure 3-1/2" in diameter. That is the sum total of everything I know or can find out about it.
If anyone can post a link to specifications for American Axle & Manufacturing rear axles I would appreciate it.
Of particular interest to me is the axle weight rating. That is to say the axle manufacturers weight rating - not the rating Dodge publishes on the door sticker. That rating is something like 6,000 pounds.
My plan is to put a rather heavy truck camper on. I've already got air bags to help out the leaf springs. I plan to replace the LT tires and 17" wheels by adding 19.5 Rickson Wheels with some killer truck tires pretty quick.
There's no need to over do it though - if the axle itself will only carry so much, so be it.
That about says it - if someone can help me out on the axle weight rating as put out by the manufacturer I would appreciate it.
Pictures with all kinds of weird numbers follow.
2005 Dodge Quad Cab Heavy Duty 4X4 5.7L Hemi.
Air Lift Remotely Controlled Air Bags.
Hellwig Rear Anti Sway Bar.
Viair Onboard Air System.
Old 09-23-2010, 01:53 PM
Rep:1625
Old 09-23-2010, 02:01 PM
RamTech RamTech is online now
Rep:1909
If I remember correctly the 11.5" AAM is rated around 10k lbs.
