Old 09-22-2010, 12:02 AM
jnr7510 jnr7510 is offline
Vehicle: 2000 dodge ram 1500
Trim Level: 4x4 reg cab 5.2
Color: blue
jnr7510 is on a distinguished road
Default sensor problems?
i just bought a 2000 ram 1500 4x4 and so far the speedo stoped working and the odometer stoped working aslo the check engine light is on and the abs light is on as well. the breaks work fine with no problem. i took it in and they hooked it up and there was a bunch of things:
1.vehicle speed sensor circuit condition.
2.the ecm has detected a fault in the vehicle speed sensor circuit.
3.poor electrical connection or short circuit.
4.failed vehicle speed sensor
5.drive gear mechanical fault
that is what it said at autozone. so what i am asking is should i go ahead and buy the speed sensor or is this something more then that? also would the speed sensor cause the things in the cluster to go out like the speedo and the odomoter? thank you i hope i have giving enough info. i really need the help because i am in tennessee and we have emissions testing and they won't pass a car if the check engine light is on. thanks
Old 09-22-2010, 12:16 AM
It sounds like it has a bad speed sensor . 1 problem could trigger a number of different trouble codes .
Old 09-22-2010, 10:29 AM
Color: blue
ok thanks i will try that
Old 09-22-2010, 02:59 PM
Rep:1845
Uh, since when did we start emissions testing in Tennessee?
Old 09-22-2010, 04:02 PM
Color: blue
we started it in 2004, i live in chattanooga, but i think we are the only ones that do it in tennessee. maybe knoxville does it i am not sure
Old 09-22-2010, 04:21 PM
Rep:1845
Must be a local deal. We don't have it here.
