Old 09-22-2010, 01:36 PM
Danno's Avatar
Danno Danno is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie 4x4 Xcab
Danno is on a distinguished road
Default Timbrens in the mail
Ordered a set for the rear. Hopefully will get them installed over the weekend. I think I'm going to POR-15 the area before installation just to be safe.
I've currently got the bed about 3/4 full of loosely thrown firewood and it is sitting perfectly level. The truck seems to handle much better with the weight in it. acceleration and braking feel like I'm totally empty!
I'd like to be able to fill the bed with firewood and then tow my teensy 1,000lb trailer. When loaded like that i want to at least carry the weight right. I don't think I'll be doing anything too crazy or unsafe, but I'll probably (technically) be a little over the GVWR.
The more I read around, the more I'm wondering how on earth this thing is rated to have a payload of 1600+lbs (per MSN Auto). I bet that by the time I get me and some fuel in the truck i have more like 800lbs given the weights I'm reading about for the truck itself. Throw my entire family and a few random things into the truck and the payload really drops. BUT, it seems to handle that payload really well, so I'm not worried. I might be able to get a weight on the empty truck sometime this fall at Dad's new grain bin setup on the farm. He's got some fancy new scale system for the big trucks.
I bought a 13 year old truck because i didn't want to be afraid to push it every once in a while. Most of the time it will be babied, but let's hope it takes the occasional abuse!
Old 09-28-2010, 09:51 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Let us know when you get it and how you like it!
Old 09-29-2010, 09:17 AM
Danno's Avatar
Got them last friday and had them installed within 30 minutes of opening the box.
They don't require drilling or welding or anything except removing the old bump stop and utilizing those holes for the new Timbren. Unloaded I had only about 1/4-1/2 inch of space between the timbren and the bump stop "plate" and they recommend one full inch so they don't impact your unloaded ride. It's not been a problem for me.
I made a couple of trips to the timber to get wood and it handled the loads excellently. One load had to be 1500lbs or so and the more recent load was with my entire family and about 2,000lbs of Hickory in the bed. the truck handled it with absolutely no problems. engine and braking did well, no sagging at all, so the geometry of the suspension was held in check. I wasn't aimed at the sky, so that was nice, too. 2,000lbs+ is probably more than one should do, and I won't make a habit of it, but it was nice for the peace of mind for planning other things that I might not have even considered. at no points did I feel unsafe with that load, although you have to watch your tires at that point (especially if they are nearing the end of their lifespan). The axle isn't built for that kind of abuse, so I wouldn't recommend the overloading on any sort of regular basis.
All-in-all I highly recommend these ESPECIALLY if you use them for what they are prescribed for: Improving the handling of loads that were already within the GVWR listed for your truck. If you insist on doing more than what your truck was made to do (like I do) then I suppose they are also a good option.
For the easy install and the <$200 price tag delivered to my door, I can't think of a better option for me.
Can you tell there is about 2K lbs of hickory in there?
