Lamp Out Chime is driving me nuts - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 09-22-2010, 04:37 PM
brianrobert's Avatar
brianrobert brianrobert is offline
Vehicle: 2003 Ram 1500 4 x 4 Quad Cab
Color: Navy Blue
brianrobert is on a distinguished road
Default Lamp Out Chime is driving me nuts
I have a 2003 1500 4x4 Quad cab SLT . And love it !! However I am being driven nuttz by an intermittent Lamp out chime . It doesn't come on all the time , but often enough. If I touch the brakes "DING" usually only once , not more than 3 times ...then it stops . The same with the left signal , and sometimes when I put the shifter into reverse (5 speed standard ) it will chime then too, without touching the brake pedal, signal arm or anything at all . ALL LIGHTS ARE WORKING ....Sometimes I can drive for days without it happening once.....other days it s non stop ....Can anyone help me out
THX...Brian
Old 09-22-2010, 05:03 PM
As I stated in your newbie post , as intermittent as it is , it sounds like a bad connection somewhere . Possibly a ground . Next time it does it , have someone check your lights for ya while it's acting up .
Old 02-26-2011, 11:23 PM
thedvsmonkey's Avatar
thedvsmonkey thedvsmonkey is offline
Vehicle: 2007 Ram 5.7L Hemi QC 4X4
Rep:70
thedvsmonkey will become famous soon enough
I just experienced something similar and turns out my rear turn signal bulb was out. I replaced the bulb and the chime went away! I guess those bulbs are double filament so even though the light was on the turn signal filament was burned out and that was what was causing the problem. Good luck!
Old 02-27-2011, 12:58 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Ran into that exact issue with my 2004 a few years ago. I finally removed both tail light assemblies, and re-seated all the bulbs. End of problem.....at least for me.
brad
Interested in one of my mods?
Old 02-27-2011, 11:44 AM
Color: Navy Blue
Thumbs up
Yeah that is pretty much what I have been doing.... It goes away for months and then all of a sudden " Its Backkkkk" I only remove the left side assembly and make sure all the connections are clean and seated properly in the connector and am good for a few months .
Old 03-07-2011, 09:10 PM
Readyakira Readyakira is offline
Vehicle: 2005 ram 1500 quadcab 4x4
Readyakira is on a distinguished road
are you putting any anti-corrosion on the connection when you are re-assmebling it? Also could be a loose pin. Now that you have it to a side, it should be much easier to get fixed.
Old 07-01-2011, 10:52 AM
don482005 don482005 is offline
Vehicle: 2012 Outdoorsman
Color: True Blue Pearlcoat/Mineral Gray Met. Clear Coat
don482005 is on a distinguished road
put Di-Electric Grease in each socket it worked for my dodge
Old 08-06-2011, 06:50 PM
1969A56 1969A56 is offline
Vehicle: 2002 Dodge Ram 1500
Color: silver
1969A56 is on a distinguished road
Default lamp out alarm
That also happened to me AFTER i replace a burned out rear t/s bulb. What I found after 6 months of therapy was that the contacts on the bulb were bad and would intermittently arc (going over bumps or bad roads) causing the lamp out alarm to chime. I again replaced the bulb and after paying particular attention to the bulb fitment ...that cured it!
THX...Brian
Old 08-06-2011, 07:38 PM
Rep:2954
a product that i find very useful is LECTRI-CLEAN, you can find it at any auto parts seller & computer shops
i have used it mostly on trailer plugs, male & female
it is quick drying & leaves no residue
Old 08-29-2011, 02:42 PM
Plymouthdusterman Plymouthdusterman is offline
Vehicle: 2003 Dodge Ram 2500 Diesel
Plymouthdusterman is on a distinguished road
Default Chime
You might have moisture in your tail lamp!!! Take off your left tail lamp and the strip the holds all three bulbs, and let them both dry out in the sun for a good while!!!!!!! What happens is moisture gets in the lens somewhere and sweats causing it to short out!!!!!!! I just fixed mine a week ago!!!! Works fine now!!!!!!!!! Hope this helps you, that chime get to you after awhile!!!!!
