Brake light in dash is on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 09-24-2010, 12:40 AM
RDG
Default Brake light in dash is on
Front brake pads were worn out,brake light came on.Replaced pads ,reset system brake light still on.ABS doesnt seem to be working.No blown fuses,no codes in the display.Havent owned a Dodge since 85.Tryin to figure out what to do next.Thanks for any Ideas.
Old 09-24-2010, 12:52 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Brake fluid level? Bulbs not working?
Brian:
Old 09-24-2010, 09:17 AM
Resident Technician
Rep:1915
Which brake lamp, the red one or the yuellow ABS? If it's the red one, try pulling up on your parking brake while holding the release handle.
Old 10-09-2010, 01:50 AM
gossemer75 gossemer75 is offline
Vehicle: 2004 Dodge Ram
gossemer75 is on a distinguished road
I hope you guys don't mind, but I have a question on these same CEL's so I figured I'd just add to this thread... I recently bought a '04 ram 1500 4by with a hemi. It was fine until this morning. I was driving for a few minutes ( less then five ) and both the red brake and yellow ABS light came on and stayed on. The brakes work fine, but every so many minutes the lights blink and ding. This has happened every time I got in and drove today, same deal.. drive for a couple min. then lights come on.... The only thing I can say I noticed before the lights came on, was that the brakes started a lite squeal like brake dust or wear pins... Would low break pads cause the lights??? Thanks for your input....
Old 10-09-2010, 06:11 AM
moparman4x4's Avatar
moparman4x4 moparman4x4 is offline
Vehicle: 1999 dodge ram 2500 v10 srt
Trim Level: fully loaded $32000.
Color: white /black sport trim
moparman4x4 is on a distinguished road
to (GOSSEMER75) yes if your pads or shoes are wearing thin then your brake fluid is also getting low as well. rotors are not cheap replace your pads and or shoes ASAP. bleed them good I always do it twice per wheel remember if you replace the rear shoes bleed the right side first it is then the left rear then front right and front drivers side last and be carefull with them bleeder screws very easy to brake and Good Luck your Dodge sounds like a sweet rig
Andy
Old 10-09-2010, 08:14 AM
Resident Technician
Rep:1915
If the amber ABS light is on, you need to have the module scanned for codes.
Old 10-13-2010, 10:29 AM
Thanks guys for the great responses... The trucks at the dealer getting worked on as we speak....
