Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-24-2010, 05:12 PM
Reed44 Reed44 is offline
Vehicle: 2000 Dodge Ram ext.cab 4x4 5.9
Color: dark green
Reed44 is on a distinguished road
Default o7 ram highway shimmy
My friend has a 2007 ram hemi 4x4 with general grabbers on it, 305/50/20. we went mudding one day and his powersteering pump went out so we replaced it then like a week later he started getting a bad shimmy in the steering wheel on the freeway. All the wheels are tight and the wheels have been re-balanced twice and it still does it. Any ideas?
Old 09-24-2010, 05:38 PM
RamTech RamTech is online now
Rep:1877
What about the steering and suspension links? Are they tight as well? Wheel bearings?
Old 09-24-2010, 11:32 PM
He doesn't have any mud stuck on the backside of the wheels does he ?
Old 09-25-2010, 08:19 PM
Color: dark green
front end is tight. i just did the alignment. no mudd packed in there. tires where put on after we went mudding
Old 09-25-2010, 09:41 PM
Rep:1877
What speed is the vibration showing up? Did you rotate the tires when you balanced them to see if the vibration moved to the back of the truck? Did you do a regular spin balance or a road force balance?
Old 09-28-2010, 09:11 AM
Color: dark green
usually happens after 50mph and changes depending on road condition. we didnt road force them and havent rotated them either
Old 09-28-2010, 09:16 AM
Try a rotation to the rear. I had to road force balance my 285/75RX18's to get rid of tire problem causing vibration and a shimmy.
Old 09-28-2010, 06:29 PM
Color: dark green
I will try that saturday.
Old 10-05-2010, 01:15 AM
silvermist's Avatar
silvermist silvermist is offline
Vehicle: 08 dodge ram quad cab 1500 4x4
Trim Level: sport
Color: sunburst orange
Rep:37
silvermist is on a distinguished road
if it is a 2500 or 3500 with the soild front axle check the front steering dampner and ball joints it is common i have heard in those trucks look on you tube for ram death wooble the steering dampner is the quick fix the steering components is the real fix
