Old 09-24-2010, 04:23 PM
09 TRX AGGIE 09 TRX AGGIE is offline
Vehicle: 2013 1500 Black Express 4x4
Rep:130
09 TRX AGGIE will become famous soon enough09 TRX AGGIE will become famous soon enough
Question Bakings heads and fogs
are fog lights made to be "baked" and taken apart like headlights? attempting to do mine and cant quite get it....
Old 09-24-2010, 10:36 PM
I push the skinny pedal
Rep:3277
you can bake them open. You have to make sure the bulb is removed first to get uniform heat inside and out. You may have to bake them several times in order to soften them up completely since they're designed to get wet regularly. When you re-seal them, use plenty of RTV sealant
Kurtis
Old 09-25-2010, 10:02 AM
Rep:130
the bulbs were definitely taken out. they were in the oven close to 45 minutes at 225 and they wouldnt release all the way around. i havent decided if i am up to trying again. i already chipped part of the housing trying to get it apart.
Old 09-25-2010, 10:46 PM
DeepWaterHemi's Avatar
DeepWaterHemi DeepWaterHemi is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Trim Level: SLT Sport
Color: Deepwater Blue PBS
Rep:276
DeepWaterHemi is a jewel in the roughDeepWaterHemi is a jewel in the roughDeepWaterHemi is a jewel in the rough
DONT DO IT!!! I tried and ended breaking the fog light. They are sealed with a superglue type adheasive, it does not get gummy when heated and youre fogs will give way before that glue does
Old 09-25-2010, 10:49 PM
Rep:276
I ended up tinting the fogs to mak'em match the headlights better. Check my avatar.
Old 09-28-2010, 03:07 PM
Rep:130
thanks for that deep water. i didnt try again so now i know i shall not continue
Old 09-29-2010, 12:04 AM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
That will look great when its done.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
