2001 ram 1500 a/c problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 09-24-2010, 09:57 PM
onesht1kl onesht1kl is offline
onesht1kl is on a distinguished road
Default 2001 ram 1500 a/c problem
Have a 2001 Ram 1500 4x4 5.9L...a/c problem...recently had the contrast put in and no leaks...when i start my truck it seems like you can hear the sound of water pouring into a glass. Buddy of mine said it could be evaporator core, although not sure. Other things that might help is that the fan kicks on quite frequently when running. And a slight smell of a waxy or crayon type smell in the cab when first started. originally when the contrast was put in it was 1/2lb low..again no leaks and this was done about 2 months ago. Any help would greatly be appreciated.
Old 09-25-2010, 08:55 PM
Resident Technician
Rep:1915
I believe the noise you hear is actually coolant running through the heater core. As for the refrigerant loss, the evap core is the most likely suspect if you've ruled out the rest of the components.
Old 09-25-2010, 09:39 PM
^^ agreed^^
