ZDOG
Old 09-25-2010, 12:06 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Default leveling question
ok guys I dont know anything about level or lifting truck. Well as you guys know i got a 07 dodge ram 1400 quad cab 4x4 i was told the leveling kit is 1.5 block is that true? also i dont want to spend a crazy amount in a lift but i looking to make it a bit higher. Do any of you guys have like a 2 in lift or 3 inch i seen 5 that way to big for me. Thanks
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-29-2010, 12:25 PM
Resident Technician
Rep:1911
It depends if you want to just level the front end or raise the whole truck. I've seen some leveling kits advertised as 2".
Old 09-29-2010, 01:48 PM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
2" leveling kit will bring the front up level with the back. 3" body lift will lift the whole truck 3"
Old 09-29-2010, 06:54 PM
SilverUSMC's Avatar
SilverUSMC SilverUSMC is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Trim Level: Laramie / Quad Cab
Rep:20
SilverUSMC is on a distinguished road
I just installed the Bilstein 5100 adjustable shocks to level it with the rear. It came out to 2". It looks and rides great! Def recommend the 5100's
Old 10-03-2010, 06:57 PM
ScatPak07's Avatar
Rep:970
If you have the money I have to agree and say go with the Bilstein 5100s. They are not much more than the spacers but they are worth the money thats for sure. Leveling the truck does make it look bigger. If you want to raise the rear as well the best thing to use would be a block. Thats the easiest way to get a 2" lift in the rear.
If you go with a body lift you are lifting the body off the trucks frame basically. I would not recommend doing that since you will have some gaps and stuff. It would be better to do a proper lift instead.
Just remember though when you go bigger you will want to get bigger tires. When buying a lift make sure you have some extra money for some tires haha.
Old 10-04-2010, 10:09 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
I agree totaly!!
Old 10-04-2010, 10:14 PM
Where do you see the gaps? Stuff?
Old 10-04-2010, 10:19 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
They make gap guards for trucks that have a body lift installed.
Rep:463
I don't see any. Looks great!! So that has the 3" body lift? Which kit did you use? I am still thinking of doing a 3" body on top of my 8" lift.So the only thing I would have to do is raise my dual exast after I put the body lift on it right?
Old 10-04-2010, 10:37 PM
They put a Performance Accessories kit on that truck. It came with the gap guards, body lift, and leveling kit. Some guy in another thread found one here under $600.
Just the body lift http://www.central4wd.com/inventoryd...folder%7C96667
Gap guards http://www.central4wd.com/inventoryd...folder%7C97002
You can have a muffler shop make some turn up tips for the exhaust. Cost us $60
