Old 09-25-2010, 05:01 AM
Ramit06's Avatar
Ramit06 Ramit06 is offline
Vehicle: 2006 Dodge Ram
Ramit06 is on a distinguished road
Default 4.7 six speed swap?
i never really noticed till today that they offer the 6 speed in other model rams other than the srt10. Is there a way to convert my 4.7 with an automstic to the 6 speed? has anyone done this? and what will be needed?
Old 09-25-2010, 09:14 AM
keithh2oskier keithh2oskier is offline
Vehicle: 2010 Dodge Ram 1500 4X4
Color: Inferno Red
keithh2oskier is on a distinguished road
My guess is the cost would be super high. First the tranny has to mate up to the engine. The chances of that are slim. Then because the new trannys are computer controlled the whole computer would need to be replaced.
The idea is cool but it would be a very expensive job.
Old 09-25-2010, 09:27 AM
Adub Adub is offline
Vehicle: 2009 Dodge Ram
Rep:13
Adub is on a distinguished road
The 6spd that was offered stock behind the 4.7 is not the same transmission that was attached to the SRT10 trucks. Swapping the 6spd from a 4.7 to yours would be much simpler than going with the T56 from the SRT10. It would be a matter of collecting all the parts, everything should bolt up (minus cutting hole in floor). You might have to tune the computer as well or swap to a computer from a manual trans truck.
2009 1500 Crew Cab SLT 2wd 4.7
Old 09-25-2010, 08:26 PM
Ramit06's Avatar
I knew the SRT10 T56 was diff, i meant the 4.7s with the 6 speed trans. so if i was to get everything from a 6 speed 4.7 it would be bolt on all but the floor? what about the 3.7L v6s with the 6 speed? will that stuff work too or is it all diff engine to engine?
Old 09-26-2010, 12:05 AM
4pnt7 4pnt7 is offline
Vehicle: 2008 4.7l Dodge Ram
Color: Graphite Grey
4pnt7 is on a distinguished road
I believe its the same between 3.7-4.7l transmissions.
There should be a hole marked in the floor. I'm not sure what all you will need though.
Nicolas Chavez
2002 ram 4.7l qc (Totaled),60ft.-2.0,1/8-9.310,@76.mph,1/8-9.41,1/4-14.80,@90.94
Old 09-26-2010, 12:57 AM
keep us updated on this if you decide to do it.
Nicolas Chavez
Old 09-26-2010, 06:11 PM
Ramit06's Avatar
i do plan on doing it. just not right away. i am tryin to build the 4.7 up im curiouse how much HP is possible on the 4.7 and im not sure how much the auto transmission will hold up to so i wanted the manual trans
Old 09-27-2010, 09:22 PM
Rep:13
The same auto is holding up behind the new Hemis which have a whole lot more hp/tq than your engine does.
Old 09-29-2010, 09:25 AM
Ramit06's Avatar
it does? wow thought they used a diff trans on the hemi. thats a mind boggler. might not have to do the swap then
